Boxster BBK OEM-ish Build
Sanderzzz
Hey did you have 4 of these with the calipers.
https://www.ecstuning.com/b-uro-parts/brake-pad-damping-plate-priced-each/99635108802~uro/
They would've been on the back of the pads. These calipers are pretty noisy without them from what I have read.
No mine didn't have any dampeners on them. I'm going to try brake quiet with ceramic pads first and if they're too loud I will probably go this route. Might just go ahead and order these though since it's a problem
NorthVan1
If you order them, make sure you put these in holes first, then test fit the pads. The fit is really tight with OEM pads, not sure how it will fit with the other pads you are running. If the pads will fit, then peel the backer of the double side tape then slide the pads in.
Sanderzzz
Thanks for the tip!! Will add to the DIY!
NorthVan1
No problem, the Porsche Brembo brakes are awesome, and once installed the pads can be swapped without removing the calipers. When I had my 997 C2S and 997 GT3, I didn't use these noise reducers, as I found the noise was fine.
ZiggyMKVI
what wheels specs are needed for these to fit?
ZiggyMKVI
I've been told that the stock Detroit's need an 8mm spacer at the very least to clear, preferably 10mm. They are 18x7.5 ET51.
ok Im gonna be running Rotiform TMB's that are 18 x 8.5 et 45.. so i may still need a spacer then
Sanderzzz
I'm on VMR 710 18x8.5 et 45 so we will see. I'm hoping no spacer will be needed.
ZiggyMKVI
ok cool. So your are my test subject because I'm so close to pulling the trigger on building this same kit.
Roctre
The VMRs will fit them no question just due to the spoke design and being 18s these fit most 17in wheels. Now the rotiforms I want to say yes but they don't have a big brake(granted these aren't very big brakes) friendly spoke design so i'm not 100% sure.
Roctre
You will be fine we have the same style wheel mine is just 18x8 et45 and it will fit that fine and I know it will fit the bigger 17z calipers also. I also the rest of the stuff ordered for my boxster upgrade today so we will probably finish around the same time :)
Sanderzzz
That's great to know! Where did you end up going for your bracket?
Sanderzzz
