supreme_gti
anyone replace this part for fun? the one in my mk6 is kinda leaking or used to leak... I am thinking about replacing it (just because it leaked in the past).
there's oil residue sweat around the pump, I will take pictures.How do you know it’s kinda leaking? If it’s not broke then don’t fix it.
How long and involved was the install? Where were you noticing oil leaking? My brakes feel like trash on occasion. Might just need to bleed the system at a dealer/VW shop instead of a regular garage though.I ended up replacing the brake booster vacuum pump, LPFP, and HPFP. All three pumps replaced. Pulls feel slightly different.
The old LPFP looks really bad, the HPFP, hard to tell... the vacuum pump did leak and looks very old and worn.
Next up, figure out a way to replace the fuse box, the previous fuse burnt the F16 slot, it's fine for now but eventually needs to be replaced. I suspect the fog lights, removed the fog lights completely. So far so good. The NEW fuse (30A) has not burnt up or blown... hope not.
I will find a new fuse box. Up next on the list.
It was all replaced at a VW/Audi specialized shop, I insisted on replacing the HPFP and LPFP, since the vacuum pump is part of the HPFP (or the other way around), I think it took the shop 1.5 hours, to replace all three pumps.How long and involved was the install? Where were you noticing oil leaking? My brakes feel like trash on occasion. Might just need to bleed the system at a dealer/VW shop instead of a regular garage though.
Edit: Also were you experiencing shitty braking prior to this? Any indication the pump was failing? I see a lot of MKV FSI installs, but none on the TSI unfortunately.
