sgessler2011
Today after heavy rain here in NY i went to start the car and it took longer to start. Check engine light illuminates. Car in limp mode.
Looks like my ECU is bad. I'm tuned stage 1
Can anyone confirm this? Car is headed to dealer in morning.
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AQ HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0030
Revision: E3H25--- Serial number:
Coding: 040301081C070160
Shop #: WSC 01357 011 00200
VCID: 75CF341E1CBC9BB6B81-8020
4 Faults Found:
012423 - Voltage Supply Relay for Engine Components
P3087 - 000 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 35.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.192 V
006438 - Relay for Aux Coolant Pump (J496)
P1926 - 000 - Short to Ground
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 138 /min
Load: 92.5 %
Speed: 0.0 km/h
Temperature: 95.0°C
Temperature: 40.0°C
Voltage: 10.033 V
006439 - Relay for Aux Coolant Pump (J496)
P1927 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 49708 km
Time Indication: 0
Date: 2038.14.30
Time: 06:08:02
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 39.0°C
Voltage: 12.700 V
P3087 - 000 - Electrical Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 20.0°C
Voltage: 11.938 V
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 35.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 138 /min
Load: 92.5 %
Speed: 0.0 km/h
Temperature: 95.0°C
Temperature: 40.0°C
Voltage: 10.033 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 49708 km
Time Indication: 0
Date: 2038.14.30
Time: 06:08:02
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 39.0°C
Voltage: 12.700 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 20.0°C
Voltage: 11.938 V
