DIY LED licence plate lights
mattyICED
Got this set from PYSpeed. :thumbsup:
Heres what the box looks like
Everything out of the box
So lets get started..
Push in the clip on the side to release the light housing from the bumper.
It should look like this. Pull it out some to be able to see the connector
Now on the connector push the tab in the opposite direction of the housing
Now grab a ballast and connector harness for the new LEDs. They connect like this..
Once you get that squared away connect the new harness to the connector on the vehicle.
Ziptie your wires however you see fit
Gently slide connector and ballast through the opening and clip in the new housing.
And simply repeat for the other side!
Here is the difference..
XGC75
Imho, I wouldn't want my lights that bright. Is there any output adjustment to that kit?
EJBGTIVI
They are bright, but they look very nice in person. PIAA extreme white halogen bulbs are a good option if you want something less bright. You can get them for about $15 on amazon.
Nice write up matty.
XGC75
Or apply some lamn-x tint, maybe. Then I might worry about he buildup of heat, though - do these Leds get warm around the lens?
mattyICED
Thanks!
I'm not too sure. I'll test it out tomorrow
EJBGTIVI
Leds don't generate much heat. you would be fine putting some laminx on them. Although, like I said PIAAs would be a better option, they are only $15 vs $50 for the rdash lights .
Premium1mk6
Where is the hook up for the other side of the wire harnes . My lights are out and the warning is shown on the HUD. But today I notice being my rear passenger wheel a wire harness is unplugged
