Highgate Golfer
Hi all, I installed my door warning lights awhile back, pretty certain pins were inserted in the correct pin location on the connectors, put it back together, coded with +64 on each individual controller but they don't turn on and got error codes on the 4 door controllers. Something about an electrical fault in circuit, before I go and yank the panels again which is a pain, anybody have this problem and/or solved it as well? Any help is appreciated.
Thanks!
P.S. Original coding on the controllers was 1204 front, 1168 rear.
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWDM7AJ5BW225388
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 DB HW: 03L 906 019 DA
Component: R4 2,0L EDC G000AG 7970
Revision: 12H14--- Serial number:
Coding: 0350078
Shop #: WSC 01357 011 00200
VCID: 6EFD1BEC798C249
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2705
Revision: 05351112 Serial number: 00001101141286
Coding: 0000020
VCID: 17131E082696851
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 114B400C492400FF880E02EC92210042310000
VCID: 76CD338CC1DC1C9
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000000002
ASAM Dataset: EV_Climatic A01005
ROD: EV_Climatic_VW36.rod
VCID: 3D5FECA0AC6A8F1
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 L HW: 1K0 937 086 L
Component: BCM PQ35 M 104 0615
Revision: 00104 AE
Coding: 65180ABA80452AC4008800815000854440011F86524D8560648020200040
VCID: 3957F8B0B042B31
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 27011 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R01SF6A
Coding: 00003042
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3957F8B0B842B31
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME2512615BZZZQ
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME5F63735BZZZ6
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME7E040044ZZZO
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME4410004EZZZJ
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME07097A23ZZZE
Crash sensor for front airbag; passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME52214A25ZZZ8
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KAR001OC
Coding: 188A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 76CD338CC9DC1C9
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000152410
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 871 A HW: 5K0 920 871 A
Component: KOMBI H20 0420
Serial number: 00000000000000
Coding: 370F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 2C79D1E44710169
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 070211F2001178
Coding: 350002
VCID: 3041C5946338729
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RC1YD06
Coding: 0000002
VCID: FEDDABACA9ECD49
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0420
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAF597FC0D64489
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669362255
Coding: 010000
VCID: 28712DF45BE83A9
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001268
VCID: 3147C090A8327B1
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
012 - Electrical Fault in Circuit
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 3449C98457204E9
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2151
Coding: 0001268
1 Fault Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H15 0043
Revision: -----27S Serial number: VWZ4Z7L1102318
Coding: 2100040004
VCID: 61E770D078528B1
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001232
Shop #: WSC 01357 011 1012557
VCID: 354FF4805C5A571
1 Fault Found:
00122 - Outside Warning Light/Door exit Light; Rear Left
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001232
VCID: 364DF38C415C5C9
1 Fault Found:
00123 - Outside Warning Light/Door exit Light; Rear Right
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669352066
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01009
ROD: UHVNA_VW36.rod
VCID: E2E5FFDCF554109
End ---------------------------------------------------------------------
Thanks!
Chassis Type: 7N0
Coding: 0350078
Coding: 0000020
Revision: 00H31001
Revision: 00012001
Coding: 0000000002
Revision: 00104 AE
Coding: 009795
Coding: 00003042
Coding: 188A140000
Coding: E20000
Coding: 370F00
Coding: 350002
Coding: 0000002
Coding: 000000
Coding: 010000
Coding: 0001268
1 Fault Found:
Revision: 00H20000
Coding: 0001268
1 Fault Found:
Coding: 2100040004
Coding: 0001232
1 Fault Found:
Coding: 0001232
1 Fault Found:
ROD: UHVNA_VW36.rod
