DREKO
are you sure? if you look at the real time fuel consumption, it is blank/shows nothing when slowing down using engine braking after a downshift, but if you throw it in neutral, it will say 200mpg or something. this implies that it uses a little more gas going in neutral than when using engine braking.
as a general rule, i either downshift when i need more power or more traction/control. when neither is necessary, its fine to coast. but with such torque available at various points in the tac, i don't find it necessary to downshift nearly as much as in previous cars. i love that about this engine, that i can be in 6th around 2k rpm wanting to pass someone, and instead of having to throw into first, i can just hit the gas and the power is there. i can only imagine how magnified that is with stage I or II...
You miss understood me. I said when you are in gear with your foot of the gas, you are not using any gas. Anytime you go into neutral you are using gas just as you are ideling. When I am in gear and am coming to a stop I leave it in that gear and coast "not pressing the gas pedal while still in gear" until I slow down enough or the rpms drop too low. Then I put it in neutral. I think you and I are saying the same thing, just not getting each other! And yes the torque in this car is awesome for a 2.0 four banger. Highway on ramps are so much fun now!!!
