VEE-DUBBER
I did not change the fuse. Im not even sure which location it's on that panel.In the driver's side dash fuse panel, did you change the 15a LPFP fuse to a 30a? I just coded out the P3073 code in ED and will flash my car this morning, coupled with the uprated 30a fuse I'll see if I run into any issues. I don't think I have the Chinese J538 module (starts with H as per TB) but I will check.
Nick you are correct about lpfp being more commonly failed. I work the back counter for VW and in the 3 years I've been there I hand out probably 4 lpfp for every 1 hpfp.
Sent from my SM-G930P using Tapatalk
