devondunphy
Just wondering, I may be nuts but is it just me or does the current fuel consumption display seem a bit odd. It seems to only change in proportion to how far down you push the accelerator pedal and not actually a correct thought out reading calculated by fuel flow or actual engine consumption. Has technology not progressed far enough to give a real readout or something? I've seen them in BMW's as dial readouts and they seem much more correct by leveling out when cruising on the highway under less engine strain, never shooting to absurd numbers like 180mpg, I think they stop around 60. And they always return to a certain number when just idling. In the GTI when you idle it goes to 80, 150, then 200 and then ---mpg all just because your not depressing on the gas pedal at all. Even if your driving at speed and let off the gas pedal it will go to high numbers then ---mpg, then as you tap lightly on the gas it will return to the three digit numbers then erratically back to something semi-normal as you drive on. So to me it just seems to be a fancy gauge to show you in a strange manner about how far down your pressing your pedal and not an actual read out of the fuel consumption. It also keeps that average fuel consumption, I've only been through one tank of gas so far so I won't make any claims on that but i'd like to see if thats the truth either by doing some math at my next fill ups... I call shenanigans, thoughts?
