HI I have a few fueling question's.
First my car share the same engine EA888 as GTI 6 ROW but it's in a VW T6 Van.
so different lpfp.
I just bought a set of "small" Opel injector's ( +19% flow) to run 100% E85 with my stage 2 remap.
Still got Oem Turbo.
I want to move to 100% E85 because where i leave E85 is half price of 93 gasoline. So i will get better performance and cheaper running.
So here are my question's:
- how do you know when your LPFB is running out of flow and you need one with more flow? some chanel to log on vagcom?
- As my engine is ROW I can implement the Loba HPFP. could it be that this would help the LPFP as it will be sucking gaz harder up stream from the LPFP pump leaving the LPFP with more headroom?
At the moment If i go higher than E30 I can feel it's missing some fuel flow. As car is stoping to push at WOT from 4500RPM as soon as I go down to less than E30 then it's all fine.
So limiting factor are surely the injector's but maybe also the LPFP.
Some tunner here says that I just need a Loba LPFP and don't bother with the injector and LPFP.
so different lpfp.
