93serprise
Long story short, got my car back from a trusted shop down the street to get a water pump replaced along with a new MAP sensor harness. I am currently using a Unitronic K04 tune, and wanted to switch over to my IE K04 tune since I acquired a Stage 2.5 Snow Meth kit. I am unable to change tunes using either Unitronics flash tool or the Powerlink from IE. I am unable to even go to stock tune using either tool. Battery voltage is above 11 volts and on a trickle charger. I reached out to IE support and after a couple of days was told just this evening that my ECU needs to be replaced because the memory is full. Is that a real situation? Is there a limit to how many times you can go back and forth between tunes before the ECU just locks up? This is definite news to me if so, and sucks major ass. I have swapped tunes probably 20 times in the last 3-4 years out of boredom honestly. Thanks for any and all help
