artur1292
Cam follower isn't that big an issue. Just change it every 10k and you're fine...
See the problem is you don't know that. I did a ton of research on this because I was thinking about getting an R. VW never said "hey we messed up and the fsi has this problem so the cam follower should be changed every x miles". Everyone is just guessing what is best. Some threads say change every 10k some threads say don't change them until you see wear on them and then there is threads that say don't replace them at all because by replacing them prematurely you are putting more wear on other things just let warranty take care of it. No one has an answer that is 100% correct. Why deal with that to begin with? The only real solution to date is to take apart your camshaft and send it over to h2sport in Canada so they can upgrade it to a different style that won't wear as quick.
