034Motorsport
Group Buy Status: CLOSED
We're proud to host a Golf MkV/MkVI exclusive Group Buy on the Density Line Strut Mount Pair for MkV & MkVI Chassis Volkswagen and 8P & 8J Chassis Audi models! :thumbup:
Retail: $99.50 + Shipping
Group Buy:
1-10 Participants: $93.50 + Shipping
11+ Participants: $87.50 + Shipping
Coupon Code:
MkV-MkVI-Strut-Mount
Terms & Conditions:
1) A deposit of $87.50+ Shipping is required to participate in the Group Buy.
2) The Group Buy closes on April 15th, 2013.
3) Orders will ship after the Group Buy ends, and once the Density Line MkV/MkVI Strut Mounts are back in stock.
Group Buy:
Coupon Code:
Terms & Conditions:
034Motorsport's Density Line Mounts are the new standard in comfort and performance. Our mounts are redesigned with performance in mind, and manufactured from high-durometer rubber for increased performance and durability, without sacrificing comfort. Density Line Mounts are void-free and fluid-free, eliminating the slop associated with the factory mounts.
Track Density:
The Track Density Strut Mount Pair is manufactured from 75 durometer rubber, which is approximately 50% stiffer than stock. The steel strut mount bodies have also been redesigned to cope with the added stresses of spirited driving.
The result is a significant redultion in deflection of the strut mount, solid shifting, and virtually no wheel hop. These mounts will also eliminate the annoyoing "squeaking" sound often caused by the stock strut mounts when paired with coilover suspensions. Track Density Strut Mounts will only cause a minimal increase in noise, vibration, and harshness (NVH) inside of the cabin. These mounts are a completely re-engineered performance solution, not just inserts for use with the factory mounts.
Features:
- Manufactured from 75 Durometer Rubber
- Elminated "Squeaking" Sound Casued by Factory Strut Mounts
- Reduced Strut Mount Deflection
- Maintain Proper Suspension Geometry Under Load
- Improved Steering Feel & Handling
- Complete Drop-In Replacement of Factory Strut Mounts
- Sold as a Pair
- 2006 - 2013 Audi A3 (8P)
- 2006 - 2013 Audi TT / TTS / TT RS (8J)
- 2005 - 2009 Volkswagen Eos / GLI / GTI / Jetta / R32 (MkV)
- 2010 - 2013 Volkswagen Eos / GLI / Golf / GTI / R (MkVI)
- 2006 - 2013 Volkswagen Passat / CC (B6)
- 2008 - 2013 Volkswagen Tiguan
- 2012 - 2013 Volkswagen Rabbit
- 8J0 412 331
- 1K0 412 331B
- 1K0 412 331C
- 1 Year Limited Replacement Warranty (If you encounter any issues with our products outside of the warranty period, we will work with you to provide a resolution.)
Density Line Mounts are manufactured from high-durometer rubber instead of polyurethane for a number of reasons. While vulcanized rubber mounts are more expensive to prototype due to increased complexity of manufacturing and high initial tooling costs, rubber is inherently better than polyurethane as a damping medium for mounts and bushings.
Rubber is able to deal with stress under both tension and compression, while polyurethane mounts rely on the damping medium to be effective only under compression. Rubber is also excellent in shear, where polyurethane is ineffective, making it ideal for suspension bushings that apply a shear force to the bushing during articulation.
Rubber does not pack and wear like polyurethane does, which ultimately results in a long-lasting part with consistent performance and comfort.
Technical Insight:
While the redesigned Volkswagen/Audi strut mount for the MkV/MkVI and 8J/8P chassis was a great improvement over the previous generations of strut mounts, they leave much to be desired when paired with perormance dampers or coilover suspensions.
Many owners experience a "squeaking" sound coming from the front strut mounts after installing performance dampers or coilover suspensions. The noise becomes noticeable when pulling out of driveways, going over sped bumps, or traveling at low speed over uneven surfaces.
This "squeaking" is caused by the low durometer rubber used in the factory strut mounts, which causes the steel center cup to move inside of the rubber mount. Our Track Density Strut Mount Pair was designed to eliminate this annoying issue, and improve the performance of the vehicle's suspension.
How to Order:
1) Add the Density Line MkV/MkVI Strut Mount Pair to your cart.
2) Proceed to checkout.
3) At the checkout screen, enter the promo code MkV-MkVI-Strut-Mount, and click "Redeem" as shown below. A red confirmation box will appear towards the top of the page with text confirming that the code works.
4) Select PayPal and click "Continue" or Credit Card and enter your credit card information, and click "Continue". Your credit card will not be charged.
5) At the confirmation screen, verify your shipping address, billing address, and the total.
6) Check the checkbox to accept terms and conditions. Click "Confirm Order" to finalize the order, and process the payment.
