Darryl@HPA
High Performance Brake Kits
HPA is pleased to offer its High Performance Brake Kits for Mk4/Mk5/Mk6 VW and Audi TT/A3 applications. The HPA Brake Kits are designed in conjunction with BAER Brakes and proudly made in the USA.
Key Design Elements:
Wheel Fitment: Unlike most Big Brake Kits, the HPA system is designed to fit behind the OEM 18" GTI, GLI, or Golf R wheels without any spacers. Note: Factory dust shield must be removed to accommodate larger rotor.
Weight Savings: These kits shave 6 pounds of rotational mass per rotor, which results in improved acceleration and deceleration, and a total of 32 pounds of un-sprung weight for improved suspension function.
Calipers: CNC machined from billet aluminum, the fixed calipers are designed to increase rigidity, improve braking efficiency, and improve pedal feel. Featuring internal crossover pipes, these calipers have a sleek streamlined look with no fragile external components. Pistons are sized to HPA specification with exact piston bore for perfect front and rear balance. Piston seals protect from dust, weather, and pressure to meet DOT spec.
Rotors: Two piece floating rotor with directional curved vanes, and HPA curved slots. Hats are anodized CNC machined aluminum, and discs are zinc-plated for corrosion protection.
Pads: The ceramic compound pads included with the kit are suitable for street and mild track use. They create minimal brake dust and are relatively quiet. Sharing the same profile as Corvette C5/C6, there are many different replacement options available on the open market. Note: the OEM pad wear sensors are eliminated.
Features:
Clears OEM 18" Wheels with NO Spacer Required
Un-sprung Weight Savings of 16 lbs. Per Side, 6 lbs. on the Rotational Weight of Each Rotor
Choice of Red, Black, Silver or HPA Blue
Readily Available Replacement Parts
One Year Warranty
Front Brake Kit
Includes:
Front 6 Piston Radial Mount Caliper
Slotted Two Piece floating Rotor 355mm x 32mm thick
Caliper Brackets
Ceramic Pads
Mounting Hardware
DOT approved Direct Fit Stainless Steel Braided Brake Lines
Brake Bleeding Accessory
Rear Brake Kit
Includes:
Rear 4 Piston radial mount caliper
Slotted two-piece floating rotor 335mm
Caliper brackets
Ceramic pads
Integrated backing plate w/custom drum e-brake
Custom cables
DOT-approved direct fit stainless steel braided brake lines
Mounting hardware
Package pricing is available on the purchase of a front/rear brake kit combination. Contact HPA for details.
Additional information on HPA's High Performance Brake Kits can be found here.
If you have additional questions regarding these or any other HPA products, feel free to IM or e-mail us directly.
To order any of our performance products contact HPA Motorsports at 604.888.7274 and place your order. Visa and MasterCard are accepted, and PayPal can be set up upon request.
Features:
One Year Warranty
Front Brake Kit
Includes:
Caliper Brackets
Ceramic Pads
Mounting Hardware
Rear Brake Kit
Includes:
Caliper brackets
Ceramic pads
Custom cables
Mounting hardware
