Is my gti worth tuning?
NotSoShadyyy
I have my GTI at around 102 miles and daily drive it for now until i get a beater. after i get the beater i do want to truly build the gti but im worried if its even worth it. onto my question. my car has about 102k miles and im wondering if its worth tuning it or am i going to blow my poor little engine to bits. i was looking into unitronic since i have their intake and am planning on getting their DP as well but their dyno sheets scare me as it states on a stage one tune it proves about +45 hp and in my mind im thinking "thats a lot of gains from a tune that states no mods needed" its either that or a cobb tuner, but like i said. im scared of blowing the motor since it is my daily. someone with experience plz help thank you very much.
PS. Unitronic tuning says that it requires 93 octane but when i look it up on my phone it says i can use 91 octane and that also confuses me. i live in cali so i only have access to 91 octane. can i use 91 with a uni tune or do i need to purchase a fuel addititve
tdream1
You’re not going to be blowing up your engine with a Stage 1 or 2 tune from most of the major tuning companies. The tunes are very dependable and have been around for 10+ years in most cases. Depending on what year you have, you’ll want to make sure you have the updated timing chain tensioner and check for chain stretch.
I’m pretty sure most of the companies offer 91, 93 and 100 octane fuel grade levels. You can send Uni an email or call them to be sure. Do not rely on a fuel additive.
AM407
I went Unitronic stage 1 on my GTI at around 150,000 km. Was totally worth it, and in hindsight I probably should have done it sooner. Sold the car at 195,000 km and had no issues. Stock clutch even held up fine.
Unitronic has a 91 tune and also a 93. I believe they call the 93 tune Stage 1 plus. I went 91 because that’s the only fuel we had around here at the time, but 93 is everywhere now. Dunno if the 93 is worth it, but I probably would have done it if the fuel was available at the time.
But yeah, if 91 fuel is all you’ve got, then definitely get the 91 tune.
Thumper
As has been stated, not going to "blow" your engine from a Stg1. That said, you should also make sure to be up to date and on top of maintenance items, I mean more than normal cause you should ALWAYS be up to date on maintenance lol.
Chain tensioner already mentioned, PCV valve, spark plugs, had a valve cleaning yet? If not already be sure to use a high quality oil and recommend changing frequently around the 5k-6k range and can adjust with regular oil analysis if desired.
