Thanks for the replies Gents, been a busy weekend, but here are my answers to your posts:
That level adjustment is only to compensate for a load in the back or something else that would make the car not level anymore. If you lowered the car the same amount front and back, then the sensors don't know anything has changed. If you put six hundred pounds in the hatch, the rear will squat and the headlights will be pointed at the heavens - that's when the level sensors kick in and lower the headlights.
Go to
Daniel Stern's Lighting page and read up on how to properly aim your headlights. Once you have everything set up, use VCDS to put the headlights in adjustment mode. Adjust the lights, then go back into VCDS to complete the set up.
Once again, do not use the level sensors to adjust your headlights. Their purpose is to compensate for an uneven load.
Thanks for the link, I've seen it before and its a great reference.
As I understand, there's only one sensor - if I'm incorrect, please enlighten me. Lowering the car causes the sensor to be at a different position (the sensor arm is now at a higher point), so effectively I believe the car now thinks the rear is always overloaded and squatting, hence the fact that the headlights are always pointed downward. I'm not crazy low, but it's apparently enough to cause this issue.
If you happen to know what sensor the ECU uses as a zero-point reference value for "level", please let me know. Otherwise, my impression is that the level sensor is that reference. A lowered car with the sensor like it is angled right now seems to be always compensating for an uneven load. Which is why I am leaning towards adjusting the sensor arm to an angle that mimics the stock position.
My thoughts are just a hypothesis right now...but if you know differently and have facts to back it up, please share your reference with myself and the group.
I don’t recall if the plastic dogbone is hollow, if not you could cut a section out of the center and get some small RC car or helicopter turnbuckles and have significant adjustability.
Pic for reference...
This initial idea was exactly my thought as well - the linkage has some voids that would need to be filled with epoxy possibly. Initially I don't think it needs it to be adjustable, but it would be a great feature. If this ends up working for me, it could potentially help others, so I may pursue a more robust part, possibly a CNC'd adjustable linkage for suspension variability.
Adjust headlights via vcds/obd11. If that's not enough, adjust the headlights manually.
Seems you've already done that though. From the factory the headlights don't shoot out straight and only illuminate the roadway. Keep that in mind as I have a feeling you're going to blind incoming cars.
I'll be sure to adjust them appropriately, and for sure I've done the adjustment by the book. As it is right now, they don't project far at all, and at night it feels unsafe...I'll have to try and take a quick video for you guys to show you what I mean. High beams are perfect, and throw a ton of light, but the low beams are way too low.
Why don't you take it back to the dealership and have them aim them again rather than fucking around with the sensor? No critical thinking required, just common sense.
I'll be honest...I don't really trust the dealership to do a proper job. I'd have to drop the car off, find a ride back and forth for my daily commute, it's quite a pain when I need to drive to/from customer sites and my office. Plus it will take them hours to get it right...if they ever do...and in the end will probably give up and tell me they can't do it correctly because my car is not stock height and will still stick me with a few hours of shop time.
Given some time and research, I know I can adjust them correctly. It may take some trial and error, but I'll have the job done correctly, no going back and forth with serivce dept., and I will have educated myself and possibly others.
Did you try the adaptation first...before manually adjusting the head lights? I did mine with the adaptation only...and it leveled my lights just fine. I was able to see my lights move up. I wonder if there's something else that's out of adjustment.
Yes, I followed the procedure from the FAQ here on how to adjust LP headlights. Could be something else out of adjustment, although I have no idea what it could be. They also seem to be installed properly, just not leveling correctly.
