MK6 K04 DSG vs MK7 Stage 2 (100 octane)
bart2278
I went back and looked at the graphs. So why do the two turbos make power in such a different way.
XGC75
Because the mk7 turbo is mounted directly to the head, and the other has a manifold.
Also the mk7 turbo is twin scroll from the factory.
No, it is not twin scroll. It's super clever, with the integrated head and coolant lines. The mk7 turbo is larger than the mk6's and the mk7 has variable cam phasing on both the intake and exhaust ports. The dual cam phasing is largely responsible for the great throttle response and early spool and the larger turbo pushes out the torque band later in the rev range which makes the mk7 much more powerful on stock hardware.
the mk7 should flash back to stage 1 and he'd get the win.
maxtdi
Mk7 can't shift... it is pulling up until every shift. And yea MK7>Anything mk6
lilonespaz
So im confused, a Stage one MK7 is faster than a stage 2 mk7?
09GTIJOE
maybe your TDI, even after the shifts the mk7 couldn't pull hard enough to catch up.
maxtdi
