So I have noticed this issue where whenever I put a window down and then roll it back up, there will be smears of moisture all over the outside of the window. It does it on both front windows, don't often put the back ones down so I don't know if it affects those.
What this suggests is that the seal/pad that runs against the outside of the window is retaining some moisture in it and deposits it on the window as it slides past.
What I am concerned about is the possibility of there being excess moisture on the inside of the door.
Anyone else experiencing this? Has not happened in several days as the cold weather has kept the moisture low and/or frozen.
