Hi. I recently received a reverse led and it is causing a bulb out error. It worked great, super bright, and fits perfectly. Only problem is that annoying bulb out error on the dash.
Anything I can do to fix the problem? Or is it a bad led?
Sent from my [emoji337] using Tapatalk
Flip it 180 degrees.
There should be no bulb out error, if we have more info we can help you better.
1. do not use reverse when the car is off or in accessory mode, this will trigger an error with the LED.
2. make sure the bulb is secure in the connection
3. try to flip 180 to change voltage
4. is error only happening on 1 or both sides?
5. please try switching the bulb from one side to another.
6 how long after you installed did you see the errors or how long have you had the bulb installed?
Common causes of errors:
bad/loose connection
not having the car on
Please keep us updated so we can help you.
Thank you
