robeeeerob
Ah, I see. Np man, glad to help! Let us know if you have any more questions, and when you get it all fixed up [emoji16][emoji106]
I wonder how many have had this problem, because I did the same thing to my brown wire when I got these. ?Woo wee my lights are now working properly and error free I retightened the t-taps for the yellow wires on each side and decided to open and re-tap the other red resistor wires to the THICKER brown wires on each side. Upon examination I realized that I had actually severed the thinner brown wire on the right side and had to reconnect it using a butt splice ( this was causing side light out errors oddly)My placement of the resistors are iffyand I should have placed them further away from the plastic trim but it took about 1:30 minutes for each resistor to heat up to 'warm' anyway so I shouldn't be an issue. Basically for anyone reading this in the future don't repeat my mistakes lol
AND again thanks Rob for your help and thank you DeAutoKey for providing essential LED kits! Will be ordering again soon.
I was having intermittent bulb out errors, it was frustrating [emoji36] LOLLol my heart sank when I saw that severed wire [emoji23]
Do you guys think Posi-taps would be a better alternative to "vamp" taps? Seems like they do less damage and would have been much more secure to place in such a tight area.
Those vampire taps are a terrible solution. Fast & cheap, but trouble prone. Try the Posi-taps & stop using those Vampires.
I'll agree to disagree on this one.
I believe this is actually the reason....We would never sell anything we thought would cause issues nor or down the road for customers.
We understand the posi-tap option but it is a bit more work and are more expensive and they will work the same as the t-taps.
I have had issues with them & more than once.
As a vendor you have to say this.... I believe this is actually the reason....
I'm agreeing to disagree.
Can we stop or do we need to continue this debate that neither of us will agree on?
And on we go. You are using the cheapest solution & not the best solution. No crime in that, too bad you don't offer a better option.
Your serve.
