Games Goblin
RCD330 with skoda sound system
Hello everyone
I have a 2006 Škoda Octavia II (the Golf MK5's Škoda cousin)
I have a Skoda columbus head unit in my car (the VW RNS 510's Škoda cousin )
My car has a factory fitted DSP with the 12-speaker sound system. Here is a picture of the DSP:
I have read through the entire thread and I am ready to pull the trigger on an RCD330 with android auto, but I just wanted to make sure it will work with my car's DSP -
I have read that people have managed to get it working with Dynaudio / Fender sound systems by disconnecting and re-connecting the battery - will this trick also work for my car? My hope is that since the RCD330 works with the VW sound systems, it can work with skoda's as well?
Here are the coding values I have applied to my Columbus to get it working with the DSP
BYTE 1: 02 Skoda Sound System (CAN DSP)
BYTE 2: 00 Sound System (active speakers)
BYTE 4: 01 Speaker Monitoring: Inactive (Sound System)
BYTE 5: 01 Equalization: Seat Altea (5P) / Skoda Octavia (1Z)
My concern is BYTE 1:
the skoda sound system is marked as CAN DSP, while the VW/Dynaudio/Fender sound-systems are marked as BAP DSP - dunno what this entails
Your inputs are greatly appreciated
Here is an autoscan of my car if it is of help :
Hello everyone
Code:
Sunday,17,December,2017,17:28:50:39616
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: TMBBSD1Z66A1xxxxx License Plate: SKODA OCTAVIA II
Mileage: 121440km-75459mi Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 47 52 55 56
62 72
VIN: TMBBSD1Z66A1xxxxx Mileage: 121440km-75459miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 LB HW: 03G 906 021 LB
Component: R4 1,9L EDC G000AG 8501
Revision: --H03--- Serial number: SKZ7Z0F3525774
Coding: 0000078
Shop #: WSC 73430 790 00000
VCID: 6AD1FCF345E5291634-803E
1 Fault Found:
001025 - EGR System
P0401 - 000 - Insufficient Flow
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 119559 km
Time Indication: 0
Date: 2017.11.08
Time: 13:44:52
Freeze Frame:
RPM: 1386 /min
Speed: 27.0 km/h
Load: 18.8 %
Duty Cycle: 14.6 %
Duty Cycle: 100.2 %
Mass Air / Rev.: 260.0 mg/str
Mass Air / Rev.: 510.0 mg/str
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1106
Revision: 04507000 Serial number: 00000602020352
Coding: 0000020
VCID: 51A34B1FC873FACE55-8004
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 113B201C092700FA881204EB901A00A1300000
Shop #: WSC 00066 123 12345
VCID: 7DFBC7AFE46BAEAEE1-8028
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 J
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3D7B07AF64EB6EAEA1-8068
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 06180AB8F80100C000080080000091AC03E000AE632085005C0020000000
Shop #: WSC 73430 790 00084
VCID: 387516BB8BC94B8672-806C
Subsystem 1 - Part No SW: 1Z2 955 119 A HW: 1Z2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SK351 12 0401
Coding: 00FFF5
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSen 11 1110
Coding: 073025
7 Faults Found:
01504 - Bulb for License-Plate Light (X)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 44
Reset counter: 158
Mileage: 119521 km
Time Indication: 0
Date: 2017.11.04
Time: 11:28:13
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
Term 50 Off
OFF
OFF
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 140
Mileage: 119521 km
Time Indication: 0
Date: 2017.11.04
Time: 11:30:06
Freeze Frame:
Term 15 On
Voltage: 12.30 V
ON
ON
Term 50 Off
OFF
OFF
00080 - Function Request - Sliding Roof
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 140
Mileage: 119521 km
Time Indication: 0
Date: 2017.11.04
Time: 11:36:33
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
Term 50 Off
OFF
OFF
01800 - Light Switch (E1)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 29
Reset counter: 158
Mileage: 119540 km
Time Indication: 0
Date: 2017.11.06
Time: 18:01:19
Freeze Frame:
Term 15 On
Voltage: 13.85 V
ON
ON
Term 50 Off
OFF
OFF
00897 - Windshield Washer Pump (V5)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 150
Mileage: 119902 km
Time Indication: 0
Date: 2017.11.18
Time: 18:21:44
Freeze Frame:
Term 15 On
Voltage: 13.95 V
ON
ON
Term 50 Off
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 158
Mileage: 120192 km
Time Indication: 0
Date: 2017.12.06
Time: 21:02:25
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 120885 km
Time Indication: 0
Date: 2017.12.13
Time: 06:14:44
Freeze Frame:
Term 15 On
Voltage: 13.80 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 56D 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0006
Revision: -------- Serial number: 35821322300343
Coding: 300101
Shop #: WSC 68203 123 12345
ASAM Dataset: EV_EPHVA18VW4110000 001007
ROD: EV_EPHVA18VW4110000.rod
VCID: 336F21979AAFA8DE47-8066
1 Fault Found:
12658720 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 140
Mileage: 119521 km
Date: 2017.11.04
Time: 11:28:11
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 S HW: 1K0 909 605 S
Component: Q3 AIRBAG VW8 026 0800
Revision: 09026000 Serial number: 0038ND0VR70Q
Coding: 0020787
VCID: 3C7D0AAB7FF167A696-8068
Subsystem 1 - Serial number: 6332MSME0E0C5E04K
Subsystem 2 - Serial number: 6342MSME0D42032FB
Subsystem 3 - Serial number: 6351HSME092D0A0CD
Subsystem 4 - Serial number: 6361HSME0929003C3
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 034 0070
Coding: 0012042
VCID: 77F7D587065784FEBB-8022
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 007 0050
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 843 D HW: 1Z0 920 943 G
Component: KOMBI H05 0112
Serial number: 00000000000000
Coding: 110F00
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 397313BFB8C3528E8D-806C
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 061213F2000953
Coding: 351303
VCID: 7CFDCAABFF71A7A6D6-8028
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H05 0112
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C5D3AEB8F91F72606-8078
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3T0 035 680 G HW: 3T0 035 680 A
Component: RNS-MID H42 5238
Revision: AB001001 Serial number: SKZ6Z7L9014015
Coding: 08020040010100A00000
Shop #: WSC 33361 790 00999
VCID: 346D228B97A1AFE65E-8060
3 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 222
Reset counter: 158
Mileage: 119520 km
Time Indication: 0
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 130
Reset counter: 158
Mileage: 119520 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 195
Reset counter: 158
Mileage: 119521 km
Time Indication: 0
Date: 2017.11.04
Time: 11:28:20
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2438
Coding: 0001014
VCID: 3777158746D744FE7B-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.2 D06 1701
VCID: 346D228B57A1AFE65E-8060
Address 47: Sound System Labels: 1Z0-035-456.lbl
Part No SW: 1Z0 035 456 HW: 532 226 800
Component: SK35-DSP 4 1000
Revision: 4 Serial number: 00012413
Coding: 0000000001
VCID: 72E1E4936D35E1D68C-8026
2 Faults Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 20
Reset counter: 255
Time Indication: 0
00420 - Front Right DSP Midrange Speaker (R104)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1T0 959 702 C
Coding: 0001022
VCID: 387516BB4BC94B8672-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000007
VCID: 74EDE28B1721EFE69E-8020
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 158
Mileage: 119520 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 158
Mileage: 119520 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 158
Mileage: 119521 km
Time Indication: 0
Date: 2017.11.04
Time: 11:28:20
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2435
Coding: 0000144
VCID: 32612493ADB5A1D64C-8066
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 336F219752AFA8DE47-8066
End-------------------------(Elapsed Time: 02:41)--------------------------
