17z is a smaller 330mm rotor, 18z is a larger 350mm rotor.would like to know what offset of Ultraleggera (18 x 8) can fit a 17z. I can get some ET35 which sounds like it would be ok.
are the 17z and 18z same width or no? I'm assuming 17z would be a bit smaller but they look the same!
No idea about that fitment though, you will need a more aggressive spoke design with a 17z since they are closer to the hub.
Sent from my ONE E1005 using Tapatalk
To the best of my knowledge, the calipers are the same width, one just sits further out than the other. That said I haven't measured both sets, so don't quote me on that.Ah. I was talking about calliper width but you are right, 17z would sit closer to the hub. That's something to consider.
I have ET45 and i needed 3mm spacer to clear them.
Hi guys.
Need some assistance. Fitted a 17z on the car and now have major clearance issues. Want to know if Team Dynamics Imola's will fit on? 8.5 j ET45
