mikejsmith1985
I'm putting this thread out there as I've got some requests for custom badges, vinyls and some other accessories.
I can do center caps for wheels, GoPro mounts, custom Badges, vent mounts for mobile devices and even print the lug covers that come with the stock wheels. I can print/cut your designs or work with you to design something one off... I'll try to add some examples to this thread as I complete projects. My equipment does have some constraints vinyls can only be one color unless they're layered. 3D prints will mostly be a single color but I do have dual extrusion capabilities, however modeling for 2 colors is more complex and time consuming. My build volume is 8"x5.5"x5.5" with my current printer but plan on building a new one in the next couple months so message me with your requests and we will work something out!
Pricing: the way I work this is you are paying me for my time, materials, and the costs of running the equipment. So objects are priced based on those factors.
3D prints: in single color ABS or PLA with a 30% Infill Density
Sizes: Height x Width x Depth/Thicnkess
For custom designs/sizes/density or Premium filaments like ColorFabb XT (strongest filament) , Wood, Flexible Filaments, Carbon Fiber (**This will not have the CF weave pattern but there is CF laced into the filament for additional strength) etc. I can get you a custom quote.
ABS is a bit more rigid than PLA and has a higher melting temp, if the item isn't going to be in the engine bay I would recommend PLA.
Vinyls:
Below are some pictures of the items I've printed. 3D prints aren't for everyone as the products are created through additive manufacturing: In 3D printing, successive layers of material are formed under computer control to create an object. This means that you can see the individual layers that comprise the object and in some cases like the FrankenTurbo Badge prototype pictured below when printing at very high speeds you can lose some detail. Slower print speeds will yield better results. There is a process with ABS where you can use Acetone vapors to liquify the outer layer of the object slightly to remove some of the visible lines and give the object a more "molded" and glossy look. I'll continue to share pictures as I get more VW/GTI objects printed and in their final production quality finish.
Keep in mind anything can be customized, GoPro mounts can have your screen name or other preferred text or logos for example.
- GoPro Mount with mounting Hardware (requires GoPro Case and screw) - 20mm x 200mm x 40mm = $20.00
- Vent Mount - 41.9mm x 70.0mm x 40.0mm = $15.00
- FrankenTurbo Badge - 56.9mm x 168.0mm x 4.0mm = $12.00
- F23T Badge - 30mm x 113mm x 4.0mm = $8.00
- FrankenTurbo "T" Badge - 42.5mm x 18.25mm x 4.0mm = $5.00
Vinyls:
- Decals: $0.25 per square inch. IE: a 6x6 image will use 36 square inches of material and cost you $9
- Shirts: Standard Color Tee Shirt (white, grey, black)
Single Color Vinyl
Single Side Simple Image
Short Sleeve: S - XL: $12
XXL+: add $1
2 Sides Simple Images: add $2
Long Sleeve: S - XL: $15
XXL+ add $1
Complex Image: add $2
Multi color images: Contact me
Specialty Shirts: Contact me
