Premium Gas
RatherBeInCabo
Only premium gas in the tank (GTI)?
What are the pros and cons if I don't use it.
The difference between regular and premium is less than $3 per tank so what's the big deal? The manual and fuel door specifies premium so use it.
pvivino
With regular gas you will set off the knock sensor. The engine will then run at reduced output. No damage done - but why drive a GTI if you don't want the full output of the engine?
ame519
That's what i figured...i heard that reg gas will get less MPG so just they cancel out pretty much
jmblur1
If you can't afford premium gas, you shouldn't be driving a brand new car... with a turbo.
/thread
Diego Armando
Mk6golfer
daihard
I could never imagine myself filling my GTI up with anything but premium.
That said, let's be clear on this. The 2010 GTI does not require premium gas. It is "recommended for maximum performance." :)
LittleJohny
$3 per tank? Consider yourself lucky then. Difference for me is more than double that. Not a huge number, but it will add up.
^ This.
MK05-HJ09
/thread
^^^ Exactly.... there's really no arguement.
In our place premium gas is higher than $3. You're lucky you have $3 premium gas there.
Ratherbeincabo wasn't saying that premium gas was $3/gal., he was saying that the difference between a tank full of regular and premium was about $3, given that most stations (here anyway) charge anywhere from 5-15 cents more per grade of fuel, I'd say that's about right.
RatherBeInCabo
What I was saying is that the difference between filling up using regular and premium is at most $3. The difference between regular and premium is generally $.020 per gallon so fill ups are about 13 to 14 gallons times $.020
thisisaustin9221
It'll pay for itself anyway, you'll get more miles on a tank of premium than regular and here in SC it's only 20 cents more for each gallon so you only spend almost 3 bucks extra.
Try using the search function, when I first got my car about 6 months ago I started a thread identical to this, I was just curious if people actually ran the premium. Now I would never put anything less in my car.
daihard
Let's not be judgmental here. Like I said above, the GTI does not require premium gas. Besides, different people have different reasons for choosing regular gas over premium. Some may have bought a GTI partly because they don't need to feed it with premium gas. :)
