Ok, circumstances leading to this error. Raining all day, and most of the weekend. Did not drive through any large puddles that I recall. Got out of my car after driving hard all the way home. Let my dog out, and then got back in my car to go get some food. Upon returning to my car, and turning over the ignition, it did it's stupid "about to stall" flutter as it does if I turn the car off, let it sit for less than 45mins, and then turn it back over. Still haven't found the cause of that.
Anyway, turned it over, it effectively stalled out on me, and then blinked the TPMS light, CEL, and ESP:Error with a flashing wrench on the MFD. I turn the car off, and try to turn it back over, and it just cranks and cranks and cranks.
I turn it back off, and turn it over again, and it cranks right up. Pulled out the laptop, and scanned it for codes and got this below.
Tuesday,25,September,2012,23:04:18:49534
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 52 55 56 77
VIN: WVWFV----------
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: Not registered 0001
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AP HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH18--- Serial number:
Coding: 0403010A1C070160
Shop #: WSC 01357 011 00200
VCID: 74C912BD177A51B835D
3 Faults Found:
050217 - Implausible Data Received from Steering Column Control Module
U0429 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Date: 2112.00.00
Time: 00:00:00
Freeze Frame:
RPM: 1065 /min
Load: 12.9 %
Speed: 0.0 km/h
Temperature: 100.0°C
Temperature: 59.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Date: 2112.00.00
Time: 00:00:00
Freeze Frame:
RPM: 1065 /min
Load: 13.3 %
Speed: 0.0 km/h
Temperature: 59.0°C
Voltage: 12.192 V
049154 - Powertrain Databus
U0002 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Date: 2112.00.00
Time: 00:00:00
Freeze Frame:
RPM: 1015 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 59.0°C
Voltage: 12.192 V
Readiness: 0010 0001
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 053 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2208
Revision: 05151112 Serial number: 00001008160940
Coding: 0000020
VCID: 20612EEDF3029D18015
2 Faults Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 19803 km
Time Indication: 0
Date: 2021.14.22
Time: 22:31:32
01196 - Engine-Transmission Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Reset counter: 40
Mileage: 19803 km
Time Indication: 0
Date: 2021.14.22
Time: 22:31:33
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C492500FD880E06E992220041B70C00
VCID: 78D1268DCB1235D8195
2 Faults Found:
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 19803 km
Time Indication: 0
Date: 2021.14.22
Time: 22:31:33
Freeze Frame:
Count: 0
Count: 12
Count: 4608
Count: 8194
Count: 43520
Count: 62464
Count: 512
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 19803 km
Time Indication: 0
Date: 2021.14.22
Time: 22:31:42
Freeze Frame:
Count: 2
Count: 12
Count: 4608
Count: 16390
Count: 44032
Count: 1
Count: 512
Count: 0
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AE
Coding: 6D180A3A80252A04008800817500090447651F86534D8D60648020240040
VCID: 3A55FC85B59EE7C82F1
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 14101 26 0512
Coding: 009795
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 57
Mileage: 19803 km
Time Indication: 0
Date: 2021.14.22
Time: 22:31:34
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
01502 - Bulb for Rear Fog; Left (L46)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 136
Mileage: 17074 km
Time Indication: 0
Date: 2019.14.21
Time: 11:54:51
Freeze Frame:
Term 15 On
Voltage: 11.90 V
ON
ON
Term 50 Off
OFF
OFF
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 136
Mileage: 17074 km
Time Indication: 0
Date: 2019.14.21
Time: 11:54:51
Freeze Frame:
Term 15 On
Voltage: 11.90 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 261010F2001303
Coding: ED811F0640061200000000
VCID: EDFF87D9F45000707A3
2 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 19803 km
Time Indication: 0
Date: 2021.14.22
Time: 22:31:33
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 254
Mileage: 15768 km
Time Indication: 0
Date: 2018.14.22
Time: 18:04:27
Address 25: Immobilizer
Cannot be reached
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668801643
Coding: 020000
VCID: 277335F1562C6A2040F
No fault code found.
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: 3147DBA9A8E824909EB
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 19803 km
Time Indication: 0
Date: 2021.14.22
Time: 22:31:34
Freeze Frame:
Voltage: 12.25 V
DU
Temperature: 47.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 4C: Tire Pressure II
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 3245D4A5ADEE1F88E71
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1446940
VCID: 3449D2BD57FA11B8F5D
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 57
Mileage: 19803 km
Time Indication: 0
Date: 2021.14.22
Time: 22:31:36
Freeze Frame:
Voltage: 12.21 V
Speed: 0.0 km/h
ABS 1
Address 56: Radio
Cannot be reached
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
My mods are LED tails, and stage 2 APR with supporting mods, and no SIRIUS service on my RNS-315.
