Stage 2 endurance should be rated at 450tq. Should be fine
don't beat on it for like 5-800 miles
SB Endurance here for 16K. No issues on my DD.
I even went so far as to turn off my tune for the first 300 miles; tune on and <5lbs of boost until 800 miles.
I didnt go WOT until my trip meter said 1000.
Yeah I knew about the break in point and stuff. That's why I want to do it now. So I can get it out of the way before ko4.
Sebastian did you install yours yourself?
Here's the diy I followed. Just gather your tools before hand. I was pressed for time so I used the tool SB sent, and I fabbed it up a bit to make it work properly, but I definitely do not recommend doing that. (Made the install take longer and there is no guarantee that it works as well as oem)
If you are mechanically inclined don't shy away from the project, this was my very first clutch job
http://www.golfmk6.com/forums/showthread.php?t=73022
so i've read the write up.... sounds like a bitch. lol i dont know if im up to all that. Getting it out seems easy but putting the clutch together inside and stuff seems pretty tricky. anyone want to just take a road trip one weekend and help? lol
It LOOKS intimidating... but it really isn't once you get in there... U literally take the tranny out, unbolt flywheel, bold new one in, thencenter clutch plate, pressure plate, and throw out bearing. then reassemble. Honestly the hardest part is with the axle flange. but as long as u have a strap to help push it back in you're golden.
