Invidious
Wow, that's not even a bad driveway. If you need ramps to get home, you might be too low. Looks great anyway.
No such thing [emoji6]
Anyone having issues with passenger side axle rubbing on frame. I'm 23 3/4 ftg all around. Raised the fronts to 24 and still rubbing.
I've never had an issue when I was 24" before my notch. Knocking noises over driving over big bumps?
Yea there's a knocking noise , I checked under the car nothing else seems to be rubbing. There's no marks anywhere else and I went over all the bolts in the suspension. I ended up raising the car a tad bit more for now and it seems okay. Until I get the notch
Do you think it could have to do with my coilovers. I have the bc racing with the extreme drop kit. The shock bodies are much shorter than standard. Could the shorter length maybe be causing it to rub at that height compared to a standard coilover that the body length would be longer.
Im sure you have answered this question alot, or mabe have it posted up somewhere. What suspention setup are you running?? I was really considering bags, even have a good amount saved up but my heart has always been static idk just curious?[emoji2]
Changes coming soon
Sent from my SM-G928P using Tapatalk
