sterkrazzy
Colder air is denser so you don't build as much psi during the winter and once it warms up you see higher psi again.
Question of should or could?I’ve had my K04 for 2 summers and I’ve never seen the boost go up to 30 psi that’s why I’m curious... that makes sense though...
But I don’t recall K04 should be pushing that much boost...
It can push 30 peak, I have and its scary boost.
Can you log anything? It will tell us if its matching requests or some other issue. Also what rpm do you see 30lbs approximately?
Is it apr software? If so, iirc that is near their torque crossover point, so the turbo prolly peaks up to hit the torque request.I don’t have the ability to log but I’m pretty sure it sees 30 if I go wot on 4K rpm...
is your dv upgraded?
If you start wot at like 2.5-3k do you see this?
Have you changed anything recently mechanically?So I tried this, it will spoke to 30psi... and some surging...
Maybe this is a wastegate issue
But it would be hard to diagnose without request vs actual logs for the tune. Else we will just be fishing
So driving home yesterday in a 45 mph zone, come up on a curve with a hill/rise in the middle. Take said turn, curving right, and front end seems to lift up and "float", almost like understeer. Any ideas as to what might have caused it? I've noticed it a few times on long sweeping highway curves, at highway speeds, too.
Car is '13 GTI, DE with DSG, 4 door. Stratified tune Stg 1, 93 oct. Conti DWS06 tires (filled to 38psi), less than 5k miles on them. Used to have the 034 Dogbone Insert but removed it when the dogbone snapped and VW replaced under warranty. Car hasn't really felt right since. I have not put the insert back in because the NVH seems worse than before the mount snapped.
Thx for any infos!
