Torque specs for drain plug, etc.
Scotty2Hotty
I'm changing the oil this weekend.
Can you guys confirm these specs? It'd be nice to have them all at the top of one thread for easy searching. A lot of the information is on this forum, but it's scattered all over. I'll edit this post if I am wrong about anything.
Drain plug: 22 ft lb / 30 Nm
Oil filter: 18 ft lb / 25 Nm
Wheel lug nuts: 88 ft lb / 120 Nm
MK6 2.0T oil capacity: 4.6 liters / 4.9 quarts
grambles423
Automotive Engineer
Yes. You are correct.
grambles423
Automotive Engineer
I toss in 5 quarts and call it a day normally. Haven't had any issues.
RuckU2
Wow the 2.0 Turbo only takes 4.6qts and the 2.5L NA takes 5.8qts? Wow, that seems backwards.
Mr.Alex
I Got That 6.
Hmm...I put in only 4.5 and torqued it down to max by hand.
grambles423
Automotive Engineer
5qt wont hurt. and if your hand torquing the drain bolt, then you're not crushing the washer and providing a good seal. Definitely torque it down to spec.
Scotty2Hotty
Yeah, torque the drain plug. Using a torque wrench on the oil filter isn't really necessary. Just get the rubber seal to make contact and turn another 3/4 to 1 full turn. It will be snug.
Krazy_Z
I really wouldn't torque the filter to that spec you will never get it off for your next oil change. Don't ask me how I know this.
