FlowMK6
Hi everyone, I'm planning to change my transmission fluid for my 5MT and I'm looking for recommendations, what brand do you recommend me ? I have heard about some GM fluid. I'm looking for something which offer smooth shift on cold and high temp, I hate how it shift when it's cold outside...
Also, how many liters of fluid do I need ? For the fluid change, I just have to loosen the fill plug, then I remove the drain plug, once all the fluid is drained, I put back the drain plug, I remove the fill plug and I pump the new fluid, then I put back the fill plug and it should be done ? Do I forget something?
Thanks for your help,
Kind regards.
Kind regards.
