I searched around the forums and seems like people replace just the MC but not the booster. Is there no benefit of replacing the stock booster?
The only good one is 8J1611021E , i was quoted 220$ for a new one today, made by ATE
i have Cayenne front setup on 340x30mm discs and pedal travel is too long on my FR Leon 22.22mm piston, so gonna order the good MC
That should work nice if you can get the pump to bolt directly, for sure the pump would cost much less, you can get them for 20$ compared to 220$ for the new RS3 pump.
I heve the Touareg MC instaled, I used some short extensions on the hard lines to connect them, also consider changing the brake light switch.I've been giving consideration to bending some new hardlines and trying to install a touareg MC since that's actually what should be mated to my brake system.
