lilonespaz
Also i second putting all the R8 coils in and leaving 1 or 2 of the "good" old ones in the trunk as back ups.
t a couple places sell the real OEM red tops.
Just grabbed a set.We sell the real OEM coil packs. By themselves or in kits
https://www.moddedeuros.com/volkswagen/golf-gti/mk6-10-13/engine-parts/ignition
I put plenty of use through the original coil packs, both stock & tuned, without a problem.
Guess I'm in the minority...
Yeap, I'm trying to understand that reason why. I'm thinking them going bad has nothing to do with being tuned... they just go bad since they suck!
Same, although I had the pump done on recall while the car was the dealer.I'm still on my stock coils with Stage 1 tune since 2012 no problems. Still on my stock water pump too
Still didn't see an engineering answer for this so I'll give it a try. It's not so much that the ECU is somehow sending a different signal, it's more about the conditions in the combustion chamber.
Really briefly, a coil pack is literally a coil of wire with a bunch of current passing through it (an inductor), through a transistor or some other kind of semiconductor switch. The spark plug gap is in parallel with this switch. When the ECU tells the coil pack to fire, the switch opens, so current is no longer able to flow through it. However, the inductor basically says "there is current flowing through me, and you can't instantaneously stop current from flowing through me, and I will build up a huge voltage across me until something is able to carry this current." This huge voltage then builds up and appears across the spark plug gap, eventually causing electrical breakdown of whatever is in between the electrodes on the spark plug, causing the arc to carry current as the spark.
From my understanding, when you're tuned or have a turbo upgrade, the higher pressure, temperature, and mass of fuel and gasses in the combustion chamber may require more voltage to initiate the spark across the electrodes of the spark plug, and consume more energy to initiate the combustion process of the greater amount of fuel/air near the spark plug.
The weaker stock coils may either 1.) fail to provide sufficient voltage initiate the spark (misfire), 2.) take more time to build up the voltage needed to initiate the spark (effectively retarding the ignition timing, causing power loss), and/or 3.) not be able to ignite enough of the gas mixture due to lower spark energy (power loss and/or misfire).
This higher voltage required to initiate the spark also places greater electrical stress on the components inside the coil pack, so even if the stock coil is able to keep up and not misfire, it may still fail due to the higher voltages increasing the strain on the semiconductor switch and electrical insulation inside the coil.
This is also a reason why tuned cars are recommended to run a smaller spark plug gap. When the gap is smaller, less voltage is required to initiate the spark so it can occur more quickly, and for a given amount of spark energy, the energy density in the spark is higher allowing it to more reliably initiate combustion as intended.
OR the standard coil packs simply suck and break down over time.
