Was there still a bit of play when you just had the DG SSK or did adding the bushings removal all the play? I wonder if the bracket bushings fix the shift play I seem to experience when the car gets warmer vs cold and how the shifter gets sloppier on warm days
I ordered the shifter bracket bushings from verdict motorsports, and right now I have the 42dd, going to try this before going with diesel geek
To be fair, I think my shifter has more play than other GTI's I've been in. The DG SSK took out
most of the slop and the Tyrol bushings only took out a little which was to be expected.
Honestly get the DG SSK, it'll cost more but you'll get less play in the shifter due to the aluminum brackets and delrin pieces. Don't expect miracles with this kit alone. You notice more with the DG SSK because more of the shifter components are being replaced.
This kit would be more of an improvement on a higher mileage car. The rubber bushings + metal sleeves that are pressed into the plastic bracket are pretty stiff to begin with. Either wait until the get soft or put them in now to future proof the transmission.
