veedoubleme
I hope you didn't come here looking for instant gratification, because you won't see the sub box actually get installed for probably 2-3 weeks. I ordered it just 2 days ago, so I'm getting everything ready by mounting the amp and running wires. I'm starting the thread now, because I know Nik sold at least 20 sub boxes during his sale, so there are probably some people out there looking for install ideas. I'm adding this sub to my Dynaudio system, and I'll document all of the wires I tap and where/how I run everything.
For the sub I'll be using the MB Quart RLP254. It's handles 300W RMS. I got it off Amazon for $71, and I'm hoping it sounds great, because it's hard to find any real reviews. It also specifies an internal box volume of exactly what the UBER-STEALTH under the floor box is, so that works out well.
EDIT 2/22/2013: Regarding the sub, there have been some people who have blown theirs. See the thread here: Two blown MB Quart subs... ideas?. The OP finally replaced it with the Pioneer SW-2501 and said it sounds at least as good as the MB Quart. Just something to consider. My MB Quart also just blew out yesterday. Will replace with the pioneer.
For the amp, I wanted a good quality compact (roughly 7"x7" or less) class D subwoofer amp, of which there are very few to choose from. I chose the JL Audio XD300/1. The amp will push 300W RMS @ 2Ω, so it should be a perfect match for the RLP254, since it can be wired for 2Ω. I got the amp online through Car Audio Dealers on Amazon for $202. That's only $33 more than the more popular Rockford Fosgate PBR300X2, but this is class D and pushes 2x as much power at 2Ω. A bargain if you ask me. It's 6.85" x 7.09", so it's a little bigger than the RF amp, but it will fit where I need it.
I'm putting the amp in the hatch under the trunk mat in the lower right hand corner. I didn't want the foam to look like a hack job, and I still wanted a little storage bin, but I also needed an amp rack. I very carefully cut out a section of it and shortened it by about 8.5" or so. It's adhered with PL400 construction adhesive, so it's never going to come apart. The bond is probably stronger than the foam itself.
Next I put it back in place and very carefully made an outline of the leftover space where I could mount the amp. I then transposed that space along with the foam onto a piece of 1/2" MDF and cut out the whole area. Next, I coated it with plasti-dip, and soon the foam will be attached back onto the MDF which will solve 2 issues for me: (1) I now have a stable platform to mount my amp that doesn't involve screwing into my car, and (2) I have also raised the foam up by 1/2" so it should be very close to the height of the UBER-STEALTH sub box.
First coat of plastic dip:
Foam + MDF = Solution:
Put in place, with just enough room for the amp:
The amp and sub show up early next week, but I'm going to pre-wire everything tomorrow. I think I'm also going to need some type of structure to support the floor in the corner over the amp. I'll probably dig into that tomorrow as well.
I'll update this thread as I make progress. :thumbsup:
