What R U Running on your Golf 2.5 - Post your Mod Profile
MLue1
I just updated my Profile, some months back we installed a TTRS Pulley. we have never thrown a belt at 7500 rpm, this upgrade helps to keep that win alive.
SliMbo2.5
Feel free to add mine to original post. 2.not as slow
2010 Golf 2.5
65,xxx miles (DD)
Shark Blue Metallic 2Door
Base Trim
Manual
Interior
RNS315 Nav unit
BFI heavy weight golf ball shift knob
Nuespeed short shifter
Exterior
Stock for now (plan on doing OEM foglights and led taillights)
17" OZ Rally wheels
Rokblokz mud flaps
Performance
United Motorsports Stg 1 tune
USP CAI
Spulen vacuum pump delete kit
R8 coilpacks
Braking
Stock for now (plan on doing GLI front upgrade with SS lines and slotted rotors all around)
Suspension/Handling
Stock for now (Tiguan springs w/ Koni shocks)
rear upper stress bar
Wascally Wabbit1
Sold the 2012 and bought a 4 door auto. Really wanted the extra doors and couldn't deal with the jenky 5 speed anymore. I missed the 6 speed in my TDI which was a superb transmission. Decided to go bigger on the suspension and audio this time.
2014 Golf 2.5L
Candy White
4 Door
Automatic Transmission
90K Miles
Interior:
GTI Leather Steering Wheel
VW golfball Shift knob
Leather E-brake Handle
LED Interior Light Kit
Exterior:
Tinted Windows
Blind Spot Mirrors
Thule Aeroblade Roof Rack
Removed Golf Badge
Mill Works Tow Hook Front License Plate Mount
Black Front and Rear Emblems
Electronics:
RCD330 Stereo
Euro Switch
Uberstealth Underfloor Sub Box
10" Kicker Sub
500w Alpine Amp
Audio Control with Bass Knob
Renline Phone Mount
AAWireless
Engine:
Neuspeed P-Flow intake
IE Stage 1 Tune
Red Top Ignition Coils
Black Coolant And Wiper Fluid Caps
Transmission:
034 Motorsports Billet Dogbone Insert
Torque Solutions Billet Dogbone Mount
IE Transmission Tune
Suspension:
Bilstein B4 Struts
VWR Springs
APR 27mm Front Sway Bar
APR 27mm Rear Sway Bar
APR Swaybar Endlinks
ECS Strut Mounts
ECS Rear Subframe Brace
Ultra Racing Lower/Middle Brace
Wheels & Tires:
17" Enkei Fujin Wheels
Conti DW 225/45R17
Brakes:
Hawk Talon Rotors
EBC Red Stuff Pads
Tools:
VCDS
IE V3 Flash Tool
VCDS Mods:
Disabled Horn Honk When Locking Doors
CAGolfMk62.5
2011 Base Model with Blue Graphite Metallic paint.
Transmission:
Automatic
IE Automatic Transmission Tune
Interior:
Golf Upgraded Floor Mats
2012 Golf R Head Unit
2012 Golf R Speakers (TBA if anyone thinks they would help sound)
Exterior:
Veland Sequential Rear Taillights
Looking for Splitter but need suggestions
Performance:
IE Intake Manifold
IE Stage 2 Tune
P-flow CAI from ECS
Back Box Delete with single center exit exhaust
Suspension:
VWR Lowering Springs
Shocks: OE
Struts: OE
Whiteline Front and Rear Swaybars (Still need to install rear)
Wheels and Tires:
Wheels: Sport Tuning wheels, we're on car when purchased
Michelin Pilot Sport 4s, 225/45/17
Any mod suggestions are appreciated
usefulidiot
Transmission:
Automatic
Interior:
Exterior:
Performance:
IE Intake Manifold
IE Stage 2 Tune
P-flow CAI from ECS
Suspension:
Shocks: OE
Struts: OE
Wheels and Tires:
Sounds good! Post some pics
CAGolfMk62.5
2010 Golf 2.5
Manufacture Date: Nov.2009
ECU: Version AJ MED17
Tune: Self Ignition Advance (IE Stage1 and 2 bought, waiting installation with V3 Dongle)
Intake Manifold: UM/HEP Short Runner Intake Manifold / VW OE 07K133201K
Cold Air Intake (CAI): Self made with Skunk2 4.5 inch Velocity Stack/Filter
Oil Breather: K&N
Spark Plugs: NGK#4435 ZFR5E-11 (Copper Plugs run cooler and are only $3 each x 5)
Coil Packs: Genuine Audi R8
PCV: Stock OE with Dorman Diaphragm and Cap, with stock hose connected to UM/HEP Short Runner Intake Manifold
Oil: Castrol EDGE 5W30 year round
Vacuum Pump: Original OE VW one, will not remove
Catch Can: None (tried but too much work and messy)
Manual Transmission Fluid: VW Manual Transmission Fluid
Exhaust: OE Mid Muffler with Axleback GTI Suitcase Muffler and GTI Rear Valance.
Wheels: 16 VW Reps, 18.2 lbs, Enkei J10 wheels on order (https://www.1010tires.com/Wheels/Enkei/J10/409-670-26BK?vehicleid=75253)
Tires: 205 Michelin Pilot Sport AS3
Air Pressures: F/R 34/37
Alignment: Custom
Springs: OE
Struts: Koni Sport Yellow - adjustable
Shocks: Koni Sport Yellow - adjustable
Strut Mounts: ECS
Sway Bars: Hotchkis 27mm F / R (all fasteners torqued to 35 ft-lbs). Lubed with this Grease
Sway Bar End Links: ECS
Brake Pads: Street: Hawk HPS / Track: Porterfields R4s SOLD
Brake Rotors: VW OE 288mm (F)
Brake Fluid: VW Brake Fluid
Brake Cooling Scoops (F) Removed
Brake Bushings: VW OE
Lower Control Arm Bushings: Rear - pressed-in Febi #33973 / Front - Febi
Engine/Transmission Mount: CTS Turbo Street Performance Mount (from a Canadian Company no less)
Dog Bone Insert: ECS
TTRS Crank Pulley
Gas Pedal: Rennline REN-P45-B Gas Pedal, Heel-Toe Throttle Extension, REN PA71 Adjustable Lifter Plate SOLD
Radio: Eonon GA6153W, with backup camera; custom relay setup to turn on with reverse trigger signal
Headlights: OE VW with LED H7 replacements
ZRickety ESP Defeat, allows 2 Stage ESP(Turn off Traction Control / Totally Turn off ESP)
Comments: This car is not a Cafe Racer but it works well on track, lively handling with skinny tires, fun, fun fun. Nothing gets added unless it adds performance.
Can switch between Integrated Engineering 2.5 Tunes, Stage1 or 2 with V3 Dongle. Currently running IE Stage2 Tune with UM/HEP Short Runner Intake Manifold, 194 HP at the wheels.
Just past 280000 km no leaks dry as a bone.
Great Build. How are the R8 coils worth the purchase? Do you notice any differences when driving?
