Johnny Two Tone
[This thread is mostly a repeat of my 'door skin removal' thread but this title in this forum may garner a more direct response.]
Does anyone know how to remove the rear door windows on, specifically, the 2012 Golf? In every previous year there were 10mm bolts that were accessed through little grommet covered holes that allowed you to undue the window and pull it out of the door; the 2012 is not like that. Not only are the exterior door skins welded on instead of bolted, making it impossible to remove them under any circumstance, but there are no 10mm bolts. The only thing I can see through the holes is some kind of round, plastic thing that doesn't have a screw head pattern of any sort.
There must be a straight forward way to remove the windows to replace them if they break, or to access the inside of the exterior door skin, right?
