For those of you with a more engineering mindset, do you think the advanced timing of Uni is largely due to their lack of program switching?? APR offers program files for specific fuels, do you think that may be something that needs to be considered as well or is that a negligible fact??
I think something that needs to be emphasized here is everything that will come up is all shades of gray that look different depending on where you are standing.
The three big ones all offer excellent tunes all of which I would personally run on my car, no questions asked.
I think it comes back to what I have been harping on for years - customer service. Whoever treats you better or supports you best locally is who you should go with.
I think the lack of program switching could allow for more memory to be used on other things. What that entails is hidden within the secrecy of the company. Any trust me, they will never tell you.
Just keep in mind that our engines have NO octane sensor. Would be a nice thing to add, if the ECU has port for it. That way, you could modify a timing curve to WHATEVER gas you had. Until then, I'm guessing they run the timing profiles off of experience, knowledge, and testing.
I think APR's files offer more flexibility in terms of locale and choice of octane and OOPS moments (89 fill ups). But also the aggressiveness of the 100.
Like Bender said, I really wouldn't have much question running the APR (Obviously....I'm already running them ) or GIAC tune in terms of program switching. Unitronic I would have hesitation since our gas is so mixed and crappy here and picking ONE file would either limit my power......or my gas station choices.
Matter of fact I wind up using a big western PA grocery chain for fuel just because it's convenient for me
Nooooooo don't put Giant Eagle gas in your car! That makes Bender sad!
Not at all, think of it more like a cake mix. The main ingredients here are fueling, boost, cam timing, and ignition timing. Our main limitations are flow (turbo is the big restriction if we're dealing with a K03) and octane.
Neither way is wrong, they're just different ways of achieving results. One person might use more butter, one more sugar. You can't use a lot of both without higher octane, or you'll knock your cake off the table.
Very true. I know that having the switching was great, espeically because I am seeing more and more random octane levels. I see 92 a lot on the PA turnpike and have seen 88 octane recently. I understand each company will have secrets but clearly they are doing something right otherwise they wouldn't be in business as long as they are and each wouldn't have the backing they do.
I definitely agree with this, especially because I wind up in places that don't have shell or exxon, etc. Matter of fact I wind up using a big western PA grocery chain for fuel just because it's convenient for me. Big company I feel like I can have a little faith in their gas but for those times when I can't get to something like that or have to settle for something a little lower than 93 I like to know that I am making the decision on it.
You don't need an "octane sensor", and the only place I can imagine you'd use something like that is in a flex fuel car where stoich is wildly different.
The knock sensor is the great foot that stops the engine from being damaged. If you get bad gas, the engine can retard timing on the fly and even add fuel. Obviously, you don't want this to be happening, because you'll be losing power. But all things being equal, you can run a 93 octane map on 91 octane gas, you'll just make less power than you would on 93 if the quality of the gas is poor.
Also, don't be afraid of higher timing and lower boost, because that's how all these cars come from the factory. They run a ton of advance up top. When you bring the boost up, you need to bring the timing down. There's not a perfect recipe, and every engine is different.
The way Unitronic does things isn't inherently more dangerous, *unless* there is truth to this knock sensor deadening. If there is, all bets are off.
The lower boost in the midrange is going to account for the less midrange pull, and exacerbate the hyperkinetic nature and high rpm acceleration feelings of the engine up top with the K04, since there's some torque missing there.
If you really want to know, bring the cars to the track and see which has higher trap speeds.
To me, the style of tuning isn't in question re the APR K04 fiasco, the partial throttle drivability is. But I've heard they're revising the tune, and hopefully those customers having issues will be addressed.
I'd love to see a Stage II k04 setup with a ported billet wheel on UNI software. I know it can be done, I just think it would eat APR stage III alive.
Tuning excluded: Now you're comparing Apples to Oranges. I think ANYONE could modify a K04 and make as much, if not MORE power than a GT28 with mid level tuning.
Its about your compressor map and what you're willing to do in terms of safety. Running an IHI to its MAX......I mean.....MAX yields some great power (K04 like). I've seen it, I've talked with the individual that has done it and its not safe by any standard. In the engineering world, we call this our factory of safety. What's your bending point?
Typical philosophy is test the car at its max and dial back 1-2 steps from there for a "safe" car. Too many variables to consider breaking at that point. Why not make excellent power at 3/4 of its potential? Making THAT number as high as you can is where the reliability is.
Zach, its Lou, pls don't ban me lol.
