Did you cut out your front sway bar? Was it hard? I am probably going to remove mine when i put my air in this weekend but really dont want to drop my sub frame too much damn work just to remove sway bar.
I removed mine when i installed my accuair shit-level. Popping the subframe off is easy but you most likely will need an alignment after unless you alight it perfectly.
