Update 2. Neuspeed has agreed to send me a replacement bracket. [emoji106]
Top notch service on SupremePower and Neuspeed part.
Update. Was definitely the bracket.
So we installed my Neuspeed 25mm fsb back in April and everything seemed alright with the installation. The provided torque specs for the fsb brackets with the 13mm bolt seemed a little low, but we followed the instructions and went with it.
Fast forward to July, I am getting a new sound coming from under the car in the suspension area it sounds.
Alright so I got a new noise I am trying to diagnose. It sounds like a popping noise when taking off in first gear engaging the clutch. The popping is frequent and dies down as you get rolling. I have full mounts so I thought it was the mount but another passenger confirmed the strange sound. You do not hear it once rolling in gear above say 10mph. I do not hear it with clutch disengaged and car rolling as well.
I will try and get a video but the exhaust may mask it.
I thought it sounded like spring popping but this is while going straight in takeoff.
I also have alk and sway bars. Maybe this is coming from the endlink?
I know without hearing it you guys can't confirm, but I was just hoping there would be some specific areas I should check which would be associated with take off and not just rolling.
Someone suggested I check the fsb brackets. When I went to check the torque on the bolts, which is supposed to be 22ft-lbs, the bolt started spinning in which made me think it was loose. However, it hit the point where it seemed to stop tightening before I hit the torque spec. The bolt is not loose, it is just spinning when you tighten it (I forget which term describes this). This is the driver side. I went to check the passenger side and was reluctant to tighten it for fear of the same issue.
The bracket itself has the painted nut at the top section. My best guess is this is where my issue comes from.
So, under harder turns, I can hear this popping noise still. 90 degree Right turns for example.
What I am wondering is what I should do here? Do I replace the bracket? Is this fine unless I am doing hard turns? Only thing supporting the fsb are the endlinks and the brackets right, so I would imagine a bracket breaking off would be bad. But the 13mm hex bolts are not loose at all, they just don't go to the 22ft-lbs. I was really hoping I was done with the subframe dropping at least for the year.
