Old 02-09-2012, 01:40 AM   #15
ssims
Drives: 2012 CW 2dr 6MT
Originally Posted by smrtypants44 View Post
You pull down on the back half of the rotary knob while holding it on the close detent.
For anybody dealing with this in a 2012 this solves it. This occurs when Pinch Perfection is activated. By pulling down on the back of the knob, you override the pinch perfection momentarily. I dug around for a while before I was going to take it to dealership and it was not entirely clear...so there you go.
ssims is offline   Reply With Quote
Old 09-23-2012, 04:31 PM   #16
AXO
AXO's Avatar
My a sunroof on a 2011 GTI 19,500 miles would not close all of the way. I get the roof to close by turning the Sunroof switch all of the way open and then all of the closed several times. I plan on completing my 20,000 mile service next week, so I will post what the dealer did to repair it.
Life's a Garden, Dig It!
HOOKERS
Old 10-19-2012, 12:06 PM   #17
MaliciousMK6
MaliciousMK6's Avatar
This saved me! I was stuck in the parking lot for 15min trying to get this bastard to close!
Old 10-19-2012, 04:57 PM   #18
Wastegate13
Drives: 2015 TR GTI SE DSG LP teh acronyms
Happened to my wife's mkv. The plastic trim on the sunshade was hanging too low and would get caught coming out of the roof. It broke several of the clips, dealer replaced the trim under CPO warranty. I. Don't use the sunroof in my car other than in vent mode so I haven't experienced this.
Wastegate13 is offline   Reply With Quote
Old 10-21-2012, 12:18 PM   #19
Ina12K04GTI
Drives: 2012 GTI, APR K04/ supporting mod
Originally Posted by Chris@RevoTechnik View Post
I have never checked a mk6 but there should be a little allen key attached to the door of the fuse box on the side of the dash. You pop down the sunroof control panel and there is a hole to put it and crank it closed.
This ^^ in the MKIV the tool was located under the panel for the sun roof. This is just one of the reasons I did not get a sun roof this time around.
Ina12K04GTI is offline   Reply With Quote
Old 10-21-2012, 01:05 PM   #20
AXO
AXO's Avatar
Talking
I had my 20k service done. The dealer said my sunroof switch which was not calibrated. So they calibrated it. They also cleaned and lubed the sunroof track. So far it has been working fine!
HOOKERS
Old 10-26-2012, 09:44 PM   #21
PandaGTI
This just happened to me yesterday... I ended up using a 4mm allen wrench to close it... but you have to put alot of force to close it
So now that it is closed... is the pinch protection reset again so this doesn't happen again? or should I just not open my sunroof again...
Old 12-08-2012, 02:07 AM   #22
ghotch
ghotch's Avatar
Drives: 13 Audi S4
Does anyone know if there is a VAGCOM fix for this issue? My sunroof is not closing tonight after a short drive. What a PITA!
2013 Audi S4 Ibis White , Premium Plus, MMI Plus, Sports Diff, Adv. Key, Bang & Olufsen
2013 Audi A5 Moonlight Blue, 2.0T, Premium Plus, MMI Plus, Sport Package, Adv. Key, Bang & Olufsen
PAST: 2010 GTI..CSG, 6 Spd Autobahn
ghotch is offline   Reply With Quote
Old 12-14-2012, 07:05 PM   #23
Pryme
Pryme's Avatar
Drives: MK6 CSG 2 Door
This just happened to me today. I think the cover got pushed too far and would go in with the sunroof. I guided it forward when It would get close to closing and that work. Im afraid to open it again
Pryme is offline   Reply With Quote
Old 04-30-2013, 06:54 PM   #24
twistid
Drives: 2010 Carbon GTI
Mine has started doing this. It tries to close and when it gets to the very last bit it just opens up all the way again.
I've tried pushing down on the rails right before it pinches my fingers and pulling down on the knob while I turn it to the close position, neither one works....
Fucking VW pos
twistid is offline   Reply With Quote
Old 05-16-2013, 05:12 PM   #25
Brawn80
Brawn80's Avatar
Drives: Golf GTI MK6
Fucking VW pos
Hope your sunroof isn't still open.. but heres my observation on fixing this.
Sunroof problem just happened to me too, first "hot" day, outside temp like 80-85. As best I could tell, you can't turn it from (open) to (close) and immediately (pull down). It only worked when I finally stopped and let the sunroof cycle through once.
So to make it clear:
1. Turn from (open) to (close)
2. Allow it to malfunction and retract back into the open position
3. With the button still in the (close) position, just pull down and it should close
I was only able to do this once because it no longer malfunctioned after I did this so I don't know if the dial has to be held down, or just briefly pulled down (my best guess, held down. It doesn't hurt to just hold it down till close)
APR Stage 2 CSG 2010 DSG GTI 2 Door,SPM street turboback,Hidden Hitch,Swagman G10 bike rack on hitch,OZ Leggera 18"+BFGoodrich gForce sport comp2,KW V1 coilovers,Hardwired+Blendmounted Escort Passport 8500 X50,35% tints all around,Airbag warning label delete,Depo Dark Cherry LED tails,ECS blue tinted blindspot mirrors,deautokey LED plate lights,Michelin X-Ice Xi3(winter), Modshack Intake,R8 Coil-packs,NGK Iridium plugs,Torque mount,Rev D DV,EBC slotted front disks with EBC redstuff pads.
Brawn80 is offline   Reply With Quote
Old 09-10-2013, 12:05 AM   #26
McQueen77
this bullshit just happened to me tonight.. im still under CPO warranty so i guess im bringing it in.
Old 09-21-2013, 04:53 PM   #27
Trogdor
Trogdor's Avatar
Just had to manually close mine. Seems like all Euro cars are letting their quality slide in recent years.
APR,SouthBend,Eurojet,
AWE,BSH+RANDOM
Burninating the People
Trogdor is offline   Reply With Quote
Old 09-21-2013, 05:42 PM   #28
McQueen77
Had the dealer fix this under cpo waranty. Actuator switch and other shit. Hundreds of dollars it would have cost. Shit piece
