andylaiphoto
I just changed my oil two nights ago. I drove to work yesterday and when I was leaving for home I noticed that there was a leak. It was coming from the drain plug area and the leak left a trail of oil about a foot long and 2.5" wide, the parking space is slanted. I when I got home last night I tightened the plug even more and let it sit overnight. This morning there was an oil spot underneath the same area about 3" in diameter and you can see where the oil was building up right under the plug.
When I installed it I used one of the copper washers that it came with. I know that I didn't install it wrong and the plug is as tight as I can get it without fear of stripping it. I'm going to go back and tighten again in a minute to see if that works. But I don't have a torque wrench yet so I don't want to try to go too much tighter on it.
Two questions.
Is the plug just not tight enough?
Could it be defective?
Two questions.
