siliconcenturion
I posted this over at golfmkv, and everyone seemed to think it was useful, so I thought I'd re-post it:
Common wisdom on this forum suggests that GTI owners should shift well before redline since the turbo runs out of breath so early. I did analysis on some some dyno logs to show that this is not the case.
Here's the dyno output from a friend's APR stg1 2009 DSG TSI, with requested/actual boost superimposed.
In order to find optimal shift points, torque*gear ratio curves need to be found for each gear. These curves represent the transmission output torque of the car. Where these curves intersect is considered the best place to shift. You can read some discussion on why this is the case here.
Anyways, I wrote a MATLAB script to use the raw output file from my friend's dyno log and also used the gear ratios for the DSG to compose a graph of the different transmission torque curves for each gear. The intersection of these curves gives the ideal shift points based on this dyno information.
The graph shows that contrary to popular assumption, you really shouldnt shift more than a couple hundred RPM's before redline.
3rd gear 91oct run, same car
Low-end torque dropped compared to the 4th gear pull, so all of the shift points are higher than that run.
Here's 'stock'. Either his intake is good for 10+hp, or his 91oct tune is underperforming.
From this graph, in a stock car like this one, it seems like you should be shifting at redline all the way up until 4th gear.
DSG and 6MT gear ratios are pretty similar, so it makes very little difference as to shift points. Maybe -50rpm or something inconsequential.
Of course, this is just one set of runs from one car with a specific set of mods.
However, even given just this info, I think it's clear that you should generally shift fairly close to redline.
If you have your own dyno data (dynojet .drf output files), send it to me and I'd be happy to do the same analysis.
Hope this clarifies some things.
