Barische's Car Build
barische
APR stage 1 tune
APR carbonio intake
Audi R8 coil packs/ NGK spark plugs
Euro Short Shifter
shortened shift lever
Stern Subframe bar
ECS dogbone mount
20% rear, 40% front tint
trans fluid (gm syncromesh /redline MTL mix)
APR rear sway bar
Ultra racing mid brace
Unibrace xb
Tyrol brake caliper bushings - front
Ate blue brake fluid flush
Hardwired rx65
Front - Hawk HP+ pads (ate away rotors but great stopping power)
New set: EBC yellow stuff
rear - stoptech street performance pads
034 mounts engine/BFI trans insert w windo weld fill - track durometer
Forge side to side quick shifter
windoweld filled shifter bushings
Verdict motorsport shifter bracket bushings
windo weld Filled Lower control arm bushings
17" enkei Fujins w/ bridgestone re-11, re070 (previous = Dunlop direzza z1 star specs)
alacrity delrin black shift knob, alcantara boot
godspeed/ebay catback
H&R sport springs / Bilstein B8 mkv shocks
next mods: trailing arm, front control arm front inner bushing
H&r RSS
too stiff taken off for bilstein / h&R sport combo
400# front - 450# rear springs
IMG_4422 by barische, on Flickr
IMG_4843 by barische, on Flickr
IMG_4425 by barische, on Flickr
BFI stage 1 insert
IMG_0838 by barische, on Flickr
Forge side shifter
GTI by barische, on Flickr
034 motor mount
Stern brace
IMG_0306 by barische, on Flickr
Home race setup
auto-x helmet
wrapped the exhaust pipe with titanium exhaust wrap and stainless steel ziptie to stop the rubbing rattle..
IMG_0302 by barische, on Flickr
OEM gear oil
old sorry OEM bushings
IMG_0333[1] by barische, on Flickr
tyrol bushings -
IMG_0336[1] by barische, on Flickr
Bushing DIY - http://golfmk6.com/forums/showthread.php?t=32668
after re-11/re070 went on
IMG_4850 by barische, on Flickr
30k miles
Ukrkid37
Honestly that doesn't look like 20s in the back and 40s in the front (tint). =D Nonetheless it's clean. I'd say get some smoked side markers or color matched markers, and she'll look even better.
Once you start modding, there is never really a true "done" you're gonna wanna do more and more and more and more. =D Enjoy your car.
barische
What do you think it is then? 35% in the back and 50% in the front
barische
Apr bar installed, still have to test it put but at middle settings it feels pretty flat, less understeer
barische
New stuff, pads, bleeder, suspension bolts, fluid
Hawk hp+ front pads have sensor on both sides. Should i just remove the sensor piece out of the passenger side pad?
Cut the wire? Remove w/ needle nose? I checked the part# which are correct.
Does the rears pads have sensor as the new yellows did not come w/ sensor?
