Injector seals
DBESTGTI1
With all the talk of intake manifold replacements, removing the intake to clean valves, ect. I thought I'd quickly document injector seals on a car I put an intake manifold on yesterday.
If you get lucky the injectors stay in the head and pull out the rail, that simple, pop the o-rings off and plastic washer under it and replace them (make sure the washer is the facing the same way). Lube up the o-ring before sliding the manifold with the fuel rail back on. That's the simple part, I'm not going into any more detail than that about it.
This is for if the injectors pull out of the head. Being a direct injection engine there is a 1 time use tephlon seal that seals the injector directly into the combustion chamber. If it pulls out of the head replace it.
Here's the tool
Here's the injector taken out.
Carefully cut the seal off with a razor blade.
Use some gas on a rag and clean the injector tip, make sure you clean the end good to make sure none of the nozzles are blocked.
This is where the tools come into play, you need the little pointy piece and the 3 circular bushing looking things. The pointy cone lines up witht he tip of the injector.
You slide the tephlon seal onto the pointy part and it will stretch it out so it can slide over the end of the injector.
From here it'll sit into place but it's not usable yet because you stretched it out, it wont fit in the head without damaging something.
This is where the bushing looking pieces come in, the insides are tapered slightly. Start with the largest one and basically turn it back and forth while pushing it down. Once the big one goes on move onto the smaller one.
Your doing this to compresses the seal back down to the proper size so they fit correctly. You can't do this by hand, you will not get the fit right. After cleaning out the injector hole in the head slide it back into place, do not lube it.
crew219
Nice writeup :thumbup:
Swoope
knowledge is power, nice!!!!
beers
ViRtUaLheretic
╭∩╮(︶__︶&#6
FWIW FSI injector seals do not work on TSI injectors, found that our the hard way
DBESTGTI1
The FSI injectors are different, the seals instal exactly the same way with the same tool. Some of the early TSI's had a stupid setup that you needed parts from but FSI and TSI injector kits to get all the right parts.
Sspcivic31
Do us all another solid, and measure the bore of the three knurled seal formers :). I'm measuring the old seals on the injectors and the final diameter looks to be about 5/16". It would be real nice if i could just drill 3 holes in a piece of aluminum to form these things.
Thanks!
DBESTGTI1
The holes are tappered, that's how they compress the seals as you slide those over it, the hole gets smaller making it compress. Drilling a hole wont work.
Stocktastic1
How much is that tool?
crew219
Sspcivic31
I get how it works, the taper forms the Teflon seal so it will start in the bore(in the head) and then expand as the injector is inserted into the head pushing the seal into the injectors groove. i just wanted to know what the hole diameter (before it tapers into the tool) is at the bushing side that would be closest to the injector body. I got my buddy at work to make me a block to form them with. one down three to go.
thanks.
$250 is a lot of money for a puller, slide hammer and a coupled tapered bushings.
The Fixer
Thanks, good info.
Cryptic19111
