Ideal214
I know ecs I believe sells the auto trunk pop kit for 100$ great price and great mod for our cars. But I just dont have the funds for it so I decided to see if anyone had a DIY cheaper and works just as well. No one had a good DIY without some kind of repercussions a.e... paint scratch not fitting or closing damage to the shocks etc.
Here’s what I came up with try if you’d like works 100% for me and no damage and no extra parts needed.(DO AT YOUR OWN RISK)
Tools needed :
1.Torx 30 screwdriver
2.flat head screw driver
3.friend or something to prop the latch while you do the easy work.
STEPS:
1. open trunk easy enough…
2. take the flat head and pop off the clips for the struts and remove the struts/shoks.
3. take the torx screw and remove the black latch/hinge that goes on the body of the car and flip it the other way around with the ball closer to the body than the outside.(this makes the clearance for the strut to properly retract without damaging the car.)
4. take the strut and flip it the other way around and reinstall it with the clips to lock into place.(piston part pointing to the latch/trunk and skinny part on the body of the car.
5. do the same for the other side.
Now press and hold the trunk button on the key and BAM!!! pop trunk for free .
http://www.youtube.com/watch?v=-pTMqWTrZr0&feature=youtube_gdata_player
Only drawback so far is there’s about 1"inch less that it opens and doesn’t always open all the way on it own depending on the temperature. (The colder it is the less power the struts have)
Tools needed :
STEPS:
