Peteriroc
After 6 moths swapping pieces of my car (LPHP, HPFP, Fuel Filter, Spark Plugs, Coils,.....), I could finally run 98 file without timming pull or fuel cuts....better late than never.
I´ve solved lot of problems I had with my old tune:
- Fuel cuts and timming pull fixed:
With RevO HPFP and injectors was maxed out (91.4% load wot), now boths are more "relaxed" :thumbup:. I still have BKR9EIX (way cold APR recommedation):
- Now with APR I can boost 30 psi at 2600 rpm!!!! (NewSouth Performance Gauge) (398.23 lb-ft or 540Nm crank --> 98 file)
Boost with Revo 23 psi at 2500 rpm....
I´ll buy Audi S3 MAP to check real pressure via Vag-Com :thumbsup:
Revo support always told me is your car: "Revo never fails" :iono:.
- Better Injection timming now I could run a little more e85 with 98 file
:thumbsup:
- MAF readings and Timming Advance
- Now car pull hard till redline. With revo I had power loss shifting high gear. When I wotted 5th gear and then shift to 6th throttle randondly fails. I had to release throttle and push back
. With APR the problem is solved. No hesitation between gears.....car pull hard everytime :thumbsup:
- Moreover EMCS is great...8 programs for our MED 17,5. Now I can use antitheft program....Revo never developed this funtion in his 2.0 TSI tune
- One more thing I love is APR Revs. Limiter!!!!
:thumbsup:
