twenzel's R thread
twenzel
Whats up folks! Just picked up a 2013 Carbon Steel R this week. Got a great deal through PenFed 4 years @ .74% interest with 2k under MSRP. Just sold my 07 GT3 and my 2010 K04 CW GTI will be for sale soon. I've got big plans for this car including APR Stage 3+ later this fall.
Already have a few parts on order including S3 Aluminum front spindles and some goodies for the interior.
I'll update this thread with all mods and what not and look forward to the discussions.
Modification tracking:
Engine
APR Stage 3+
APR HPFP
APR Carbonio Intake
APR Mid Pipe for Stage 3
APR Catback Exhaust
APR Intercooler
APR Runnerflap Delete
BSH Oil Catch Can
BSH FSI Engine Mount Kit
OEM Red top R8 Coils Done!
Transmission
HPA Haldex Controller
DXD Stage 3 Endurance
Wavetrac LSD
Tyrol Sport Shift Bracket Bushings Done!
43 Draft Design Shift Cable bushings Done!
Brakes
StopTech Trophy BBK
StopTech Slotted Rotors Rear
StopTech Street Performance pads Rear
StopTech Stainless Steel lines Rear
Suspension
KW Club Sport Coilovers
S3/TT-RS aluminum front spindles Sitting in garage
H&R Rear sway bar
TyrolSport Rigid Subframe Collar kit
SuperPro Performance Control Arms
Unibrace UB and XB Sitting in garage
Wheels
18x8.5 +45 TBD
Yokohama S-Drive
Interior
RNS-510 Headunit
Polar FIS+ Advanced
OEM Euro Cup holder Done!
OEM Euro S3 Shift Knob
OEM Euro R Seats Ordered!
Whamas
Sounds promising!
Sub'd
twenzel
Later today I am going to start swapping a couple parts from the GTI to the R including the Unibrace XB and UB, Tyrol sport shifter bracket bushings and 42DD shifter linkage bushings. Pics to follow!
twenzel
Installed the 42DD bushings. Much improved in the sloppiness of the stock rubber units. I also installed the Tyrol sport cable bracket solid bushings. I really don't think it makes that big of a difference. The rubber units are pretty firm and do not have much if any play in them. Overall a low cost mod though.
mxlu1
What are the added benefits of having the S3 spindles? And are they just direct bolt ons without any other modifications?
twenzel
They are aluminum vs the cast iron spindles on the stock Golf R. This saves ~5 lbs of unsprung weight to improve handling.
Also the steering arm is shorter which improves the steering response.
Combine this with the Super Pro Aluminum control arms and a light weight brake setup like the Stoptech Trophy kit and you are dramatically improving the ability of the car.
twenzel
on the same topic. If I chose the TT spindles I could've improved the geometry when lowering the car but that requires a lot more modifications like TT lower control arms which push the hub further out. This has forced some people to buy wider front fender to keep from rubbing. So to avoid that snowball effect, I decided to stick with the S3 spindles.
