Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Regional Forums > NY / NJ / CT / PA
Old 03-22-2014, 11:49 PM   #1
vwgti2.0t
Drives: 2011 CW GTI
Cheap(er) Labor, Budget work in Pittsburgh Area
Hey fellas,
If anyone is looking to get anything changed in their car I am willing to provide some cheap alternative labor. I have done everything with mk6's there is to do, literally. Along with I've done tons of work on other vehicles as well, so I'm not limited to MK6's or even VW's. Any mods/maintenance/fabrication I can do. Valve cleaning, tensioner updates, k04/stage3+ swap, clutches, stereo systems, etc. Just post on here or shoot me a PM and I will give you an idea of how long things will take and a price. I'm in the pittsburgh area. Check out my signature and the vortex link for my cars build...I've done every single mod myself. I'm a mechanical engineer by trade and have been working on cars since I'm 10. Feel free to ask any questions through PM, or shoot me a text/call at 570-778-1464.
Search #SamoleskiPerformance on Instagram for some cool pics of things I'm working on!
PLEASE EMAIL SAMOLESKIPERFORMANCE@GMAIL.COM FOR ANY INQUIRIES.
Old 03-26-2014, 08:30 AM   #2
vwgti2.0t
Drives: 2011 CW GTI
Cheap Labor, Pittsburgh Area
My labor rate is around $80/hour, give or take. Some things are a little more or less depending on skill required. I work VERY quickly, usually much faster than most shops would. Also, some of the listed prices are based on a percentage (usually 50%) of prices I've found through local shops.
So these are ballpark estimates, but:
Clutch: $500
Clutch + LSD: $900 + shims/sealant/seals/fluid
Tensioner Replacement: $350 + OEM replacement parts
Carbon Cleaning: $300 + 4 injector kits + Cleaner
Intake Manifold Only Swap: $150 PENDING NO ISSUE. I've ran into a ton of issues with these lately. If you're using a NEW OEM manifold it would be no problem though.
K04 Install: $400
Stage 3/3+ Install: To Be determined if there is interest.
Coilover/Spring install: $250 (If doing coilovers, I would suggest also replacing the strut mounts)
DSG Flush: $140 + Materials (fluid/filter/o-ring/gasket)
Subwoofer Install (Amp Power/Ground/Signal, Tapping into speakers for line level inputs): $200 + Wiring Kit + Line Level Converter (if your amp doesn't have them) + Amp/Sub/Box. All ran neatly through OEM Wiring trays.
Door Speaker Install: $90 If going with components, it will be an extra $30 to mount them into the OEM tweeter locations.
Downpipe Install: $150
*If you are buying a raceland/godspeed/ebay downpipe, buy a REAL V-Band clamp, the ones they come with are junk and break almost immediately.
**If you are installing an ebay/godspeed/raceland downpipe on a CBFA car, it will be an extra $25 as you need to elongate the mounting holes to fit it on the turbo
***Putting a raceland/ebay/godspeed downpipe on a K04 car will require an extra O2 sensor bung added. The bung is less than $5 and will need to be welded on, I can do this.
Catback Install: $120
Diverter Valve/DV+ Install: $40
Short Shifter Install:
$30 for just the weight and cable adjustments
$60 for Diesel Geek OR Weight plus side to side shortening, plus readjusting cables.
Boost Gauge Install: $100 + Wire Taps
WALK Install: $120 for Whiteline Kit, $125 for Superpro
Tyrolsport Deadset Kit Front Install: $150 (I've never done the REAR kit, but would be willing to look into it if someone wants it done)
Rear Swaybar Install: $75
Front Swaybar Install: $150 (pending no major issues)
Intercooler Install: $200
Turbo Outlet Pipe Install: $50
Throttle Body Pipe Install: $50
BOTH ABOVE for $75
Intake Install: $50 (I'm assuming most people can do this themselves, but I'll just throw it out there anyway)
Subframe Mount Install: $50 for HPA or insert. I really want to stay away from the VWR or 034 ones at this point as it involves dropping the subframe, and I just don't have the extra hands or space (no lift) to do it.
Engine + Passenger Side Mount Install: $125
Brake Pads: $125*
Brake Pads + Rotors: $175*
Brake Lines + Pads: $160 + Fluid*
Fluid Flush: $70
Front OR Back Rotors+Pads: $100
*ALL BRAKE JOBS WILL REQUIRE YOU TO BED THE PADS/ROTORS YOURSELF. I'M NOT GOING TO GO BEAT ON SOMEONE ELSES CAR TO COMPLETE THIS!
That's all I can come up with at the moment. These prices should be (less than) half of what a dealer charges, and way under what a specialty shop would charge. I have personally done every one of these jobs multiple times. Like I said, check my build thread on vortex and rememeber that I have done EVERY install myself. If you have an issue with a price or a question about another job, feel free to PM/text me.
Old 03-26-2014, 09:45 AM   #3
GoodTimesIndeed
GoodTimesIndeed's Avatar
Drives: 2011 GTI 2Dr DSG
This is good to know. Would you do a water/meth setup as well?
Old 03-26-2014, 09:51 AM   #4
FlyByGti
FlyByGti's Avatar
Drives: '12 K04 GTI (sold)/ 09 Black 370z
subbed in case I need you in the future.
Big question is time frame for things (ex. K04, DP and Intercooler since that would be the most common thing I would think people would ask about)
K04 Club Member #36
| APR K04 | APR Intercooler | Carbonio Stage 1 & 2 Intake | Eurojet Turboback Exhaust | Red Footwells | Yellow Fogs | Spyder LED Tail Lights | New South Boost Gauge | Blue ECS Aspherical Side Mirrors Sold
¯\_(ツ)_/¯NFG( ° ͜ʖ ͡°)
FlyByGti is offline   Reply With Quote
Old 03-26-2014, 10:23 AM   #5
dimitry
Awesome. This is great to know.
In the meantime, I've been meaning to take apart some plastic panels and add a sound dampener or foam (mostly both of my doors). This might be a breeze for you given you know all the tabs and how/where to apply the pressure to pop them out.
Any interest in this?
2010 GTI (2d, white, manual, xenon, roof, dynaudio)
dimitry is offline   Reply With Quote
Old 03-26-2014, 10:33 AM   #6
vwgti2.0t
Drives: 2011 CW GTI
I mean, sure I can do anything. BUT, I've never tuned for a water/meth setup and I wouldn't even attempt to know what I'm doing when it came to programming it. I installed one in my mk4, but never actually set it up to use it. As for running the lines and mounting the tank and hooking up the pump and controller, yes I can do that. I'm assuming you would also need some sort of throttle body pipe like the bsh as well, unless you wanted it tapped right into the intercooler or other piping. I have no idea how long this would take either, but if you are sincerely interested shoot me a Pm and I'll look into it.
Intercooler is around two hours. Maybe a little more. Downpipe, pending the studs stay in tact is also around two hours. K04 would be around 4 hours. These are just estimates and can differ depending on if I'm dealing with a bunch of rusted stuff or run into other problems.
Sure I could do this. It's only a few screws and pull to get the panel off. Hell, roll by my house on the weekend with some beers and I would give you a hand no problem.
Old 03-26-2014, 05:04 PM   #7
FlyByGti
FlyByGti's Avatar
Thanks for the info. It would be cool to do this and see how everything bolts up. I wish I had been able to do it all myself, but lack of tools, location and experience really hindered that.
K04 Club Member #36
Old 03-26-2014, 05:48 PM   #8
dimitry
Man, you're the best. I'd definitely bring cash on top of the beers That said, this weekend I have to get my moto ready for the season. Riding weather around the corner!
Old 03-26-2014, 09:08 PM   #9
vwgti2.0t
Drives: 2011 CW GTI
I hear you. I really don't have a ton of space...aka a garage packed with bikes and a driveway. But I have the tools and a ton of experience. I'm a mechanical engineer by day and usually doing something car/bike related on the weekend. Plus I rebuilt my first motor at 14-15 (put a 2.3 turbo from a turbocoupe in a (carbureted) fox body along with the ecu and wiring harness ). I just love the stuff. I'd like to open my own shop in the next few years, as I really hate the engineering side of things and just enjoy working on cars. I'm getting older, so I figure now is a good a time as any to get my name out there.
No problem man! I'm usually either out of town or sitting around drinking beers on the weekends. So I figure this would be something to keep my mind going! Just let me know when you're free and we can correlate something.
Btw what do you ride? That's the other thing I do in my spare time!
Old 03-26-2014, 09:26 PM   #10
dimitry
Picked up an '09 cbr600rr last August. Love it. Never thought I'd be into the supersports, but I'm all about it. Worked a lot on my cornering in the fall. Did a nice 260mi ride through Ohio twisties (there's a nice Pgh bike group that does smaller weekly rides and some long rides throughout the season).
Before that I had an '03 Monster 620. Cool bike with so much character, but I got tired of how few aftermarket options there were and how much everything cost for it. Plus I was getting near valve adjustment mileage and reallllly wanted to avoid Ducati shop up in Wexford. Bad experiences all around. Honda is much much better in those regards (obviously), but then again, it's a completely different bike.
Next up is a supermoto Might swing it this year if I decide to keep the GTI (smart thing to do... its paid off and only 40k mi). But I'm also itching for a new car b/c of all the fucking rattles. Christ.
I've got a box full of new parts for the season... new oil, filter, chain, sprockets, levers, halo turn signals, some other extras. That's the plan for Sunday or I'm taking Monday off b/c of the weather!
Old 03-27-2014, 07:31 AM   #11
vwgti2.0t
Drives: 2011 CW GTI
Awesome man! I have an 03 Kawaskai Z1000 I ride all summer. Speaking of valve adjustments, I just did mine. LOL. I LOVE the supermoto's as well! Either way, we can continue this in PM's.. I want this thread to be some what informative.
Old 03-27-2014, 09:24 AM   #12
FlyByGti
FlyByGti's Avatar
Nice man sounds like you got a pretty solid plan laid out
Glad that you guys ride. Would be cool to get a group ride this summer for sure. Maybe we should post about it in the Pittsburgh thread (I actually think we did this before), closer to when the weather finally breaks
K04 Club Member #36
Old 03-30-2014, 04:43 PM   #13
vwgti2.0t
Drives: 2011 CW GTI
Up!
Old 03-31-2014, 09:50 AM   #14
vwgti2.0t
Drives: 2011 CW GTI
Free this weekend for anyone that needs something!
