GoodTimesIndeed
2011 Volkswagen GTI
Current mods completed on project "DEEPSLEPR"
Engine
Suspension
Brakes and Tires
Interior
Exterior
VAG-COM
Future Mods...
Engine
Suspension
Interior
Exterior
Photos of things can be seen here.
I'm always doing things, changing things, or adding things so check back from time-to-time.
Please feel free to leave comments or ask questions. Always willing to help out.
Thanks for looking! ?
Engine
- K04 APR V3.1
- Neuspeed fmic
- Custom H20 intercooler sprayer
- 2qt tank
- Hypersonic spray nozzles (2)
- Trico Pump
- Coolingmist boost trigger
- Solenoid - Custom Spectre intake with velocity stack and custom heat shield
- Eurojet turboback exhaust (3" catless)
- SnowPerformance water/meth injection system
- Snow Performance VC-50 Controller
- 375 ml/min Snow Performance nozzle (1)
- Snow Performance check valve/holder combo (1)
- Snow Performance Solenoid
- Snow Performance Wastegate Solenoid
- AEM 200 psi pump
- AEM inline filter
- Coolingmist 2+ gallon trunk mount tank
- USRT Tuner's pump pressure gauge - 034Motorsports dogbone mount
- 034Motorsports motor mount (street density)
- 034Motorsports trans mount (street density)
- HPA 75A lower puck mount
- ECS Tuning catch can system
- AWE turbo outlet pipe
- BSH throttle body pipe with meth bung (and DEI Cool Tape heat wrap)
- PTP K04 Turbo Blanket
- PTP lava wrap on downpipe
- Upgraded OEM DSG cooler (version C)
- Billet aluminum DSG filter housing
- 6.6 bar fuel filter
- R8 coil packs
- NGK BKR8EIX iridium IX spark plugs - .024 gap
Suspension
- Neuspeed 25-mm front sway bar
- Neuspeed 25-mm rear sway bar
- Neuspeed rear sway bar endlinks
- Spulen adjustable front sway bar endlinks
- TyrolSport DeadSet rigid subframe collar kit
- Stern 3-point lower rear brace
- EuroSport upper rear X-brace
- EuroSport upper front strut brace
- TCR-II Chassis Brace System
- Upper front strut brace
- Lower front stress brace
- Front tic-tac brace
- Rear tic-tac brace
- Rear lateral brace x2 - Powerflex A.L.K.
- Powerflex control arm bushings - Front position
- Solo-Werks S1 coilovers
Brakes and Tires
- TyrolSport caliper stiffening kit
- TyrolSport Master Bracket
- Centric slotted and drilled rotors (F & R)
- StopTech street performance pads
- StopTech stainless steel brake lines (F & R)
- Custom front DIY brake ducts (Removed for now)
- 56mm stud conversion
- Summer setup - Enkei Tenjin wheels with Firestone Firehawk Indy500 tires
- Winter setup - Sport Tuning T9 black wheels with Dunlop SP Winter Sport 4D tires
Interior
- NewSouth center console pod
- SpeedHut oil pressure and oil temp gauges w/customized faces
- NewSouth redline boost gauge, and DIY inline filter
- NewSouth steering column pod mount
- Snow Performance VC-50 controller in ECS Tuning angled vent pod
- AEM flow/warning - green LED
- Direct-port spray - yellow LED
- Intercooler spray - blue LED (center console)
- Intercooler spray - master on/off switch (center console)
- PolarFIS+ Advanced
- Shift-I (SGAR) progressive shift light
- 6-Drive throttle booster
- DSG paddle extensions
- 2 din Kaichuang KC-V001W headunit/FAKRA antenna/iPod cable
- Rear backup camera (in rear plate light)
- Car DVR camera recorder w/hardwire adapter
- Aesthetic Creations blank button stickers (Marbles, Oil Slick)
- Hidden master switch for w/m setup (in armrest console)
- Manual look DSG shifter boot
- Black Forest Industries DSG shift knob
- "GTI" door handle inserts
- "GTI" seat ratchet inserts
- "GTI" headrest pillows
- Dash cubby
- Driver and passenger side under-seat trays
- Seat crevice storage pouches
- Broadway Mirror - 300mm convex face
- Visor "air bag warning" removed
- Keyhole decorative ring - German flag
- Red pinstripe on dash and doors
- Non-slip front door mat inserts
- Automatic headlight conversion
- White interior LED bulbs
- Red footwell lighting
- Monster Mats
- deAutoKey LED trunk strip
- WeatherTech trunk liner
- H3R Performance MaxOut Fire Extinguisher
- Clear protective film on lower door sill to prevent scratches
Exterior
- Euro sport mesh front grill (paint matched) w/red GTI badge
- WeatherTech dark smoked rain guards
- LED door warning light w/VW logo projector
- Smoked sequential LED signals with puddle lamp
- Wide angle blue glass side mirrors w/LED arrow turn signal lights
- OEM rear rubber bumper pad
- .:R replica side skirts
- Smoked side markers
- "GTI" side badge(s)
- DIY front lip spoiler
- R32 Belly Pan Kit
- SS hardware (underhood)
- Nokya H8 yellow fog bulbs
- Nokya Cosmic White Stage2 headlight bulbs
- R20 style LED tail lights (dark cherry red/smoke markers)
- Klii gloss black rear VW badge insert
- VW Motorsport valve stem caps
- GolfMK6.com, VW Minion, Steel City Euros stickers
VAG-COM
- ESP defeat
- Gauge sweep
- Windows up/down with fob
Future Mods...
Engine
- DSG Tune - APR (maybe)
- LSD (maybe, especially if rear main seal needs replaced)
Suspension
- Powerflex rear bushings (where needed)
Interior
- Repair headliner
Exterior
- deAutoKey Slim Digital H7 HID Headlight Kit
- Possibly cosmetic pieces like spoiler, diffuser, etc...
- Not add anymore dings or scratches!
