davserbic
Those look great! Legit CCW? Also, what are the specs?
Nah, reps. I can't afford CCWs at the moment.
MAKE: ESR
MODEL: SR02's
SPECS: 18x8.5 (et30) 18x9.5(et35)
TIRES: Nankang Noble Sport 215/40s all around.
I see you're in Richmond! I'm over in the Charlottesville area.
Damn your Golf looks stunning! Thanks for the FYI on what you used to clean the exhaust tips. Wheels look great.
What a clean looking ride! Looks good with the ESM's.
Nah, reps. I can't afford CCWs at the moment. ...
Still looked good!
You can disable TPMS, that's what I did.
After you install the new SWCM, you will need to recalibrate the angle sensor. You can follow the procedure from the Ross Tech site:
Ross-Tech: Reset Steering Angle Sensor
Once they remove the Airbag and steering wheel, check the part number on the slip ring. If it is Not 1K0-959-653-C -or- 1K0-959-653-D you may need to replace it with one that supports MFSW.
I'll also note, if your vehicle has any MFA/MFD type of Instrument cluster controls via the wiper stalk this will conflict with the MFSW. If you have a base wiper stalk without any additional controls this won't be a problem.
