Hi
All new here
**** New Build on page 2***
Ride is a 2010 Golf 6 R stage ???
When i got this car it was semi modded allready so iam not sure what parts are fitted
Prewus owner have add
BCS turboback
THS intercooler.
Auto Tech high pressure fuel pump
ko4 Hybrid Turbo with larger turbine / lightweight wheels .
Heat coated surfaces. Ported manifold about 4%. Reinforced bearings,
which makes it suited for 10-15 % more pressure
It was supose to do 380-390hp but it had some air intake
problems and some injector problems as well so outcome was 340 HP
i meet up with a local tuner and we added some stuff :-D
Revo air intake
Rs4 injectors
R8 ignition coil
new sparkplugs
new oil
oooh and we changde the turbo to a TTE420
Car is now pushes 460HP and 597nm
We also did do another set up at 457 HP and 611nm
Custum DGS file too
We did test on normal road with streettyres and racelog
0-100 km/h 3,4 sec
80-150 km/h 4,8 sec
Atm we are working on WMI and hope it can provide approximately 60 hp
And we add a boost controller as well
Iam thinking on mabye getting a HPA intake manifold
but iam not sure what we can do with that
I saw that on APR stage 3 they add 35-50hp so i am not sure if we do that
and hope for 550 HP ?
We may have max out the TTE420 around the 500 HP mark
More info to come when we done with the WMI
I upload some pics and if possible, a video of the dyno test
All new here
BCS turboback
THS intercooler.
Revo air intake
Rs4 injectors
R8 ignition coil
new sparkplugs
new oil
Custum DGS file too
0-100 km/h 3,4 sec
80-150 km/h 4,8 sec
